I get this message after having upgraded from LR 5.4 to 5.7.1 I upgraded to be able to import Sony RAW files from the a7R-II camera. My
computer does not have the Adobe Application Manager, and I cant't find it on Adobe's site. This is not a trial version, as it states in the error message.
I'm using OS X 10.8.5 and don't have a subscription version of LR or PS. This was a stand alone version.
Any help would be greatly appreciated. Daniel
Sounds like you have installed the Lightroom CC Trial application. Are you running a 32 bit Mac OS system?
The Application manager can be found here: Adobe - Adobe Application Manager : For Macintosh : Adobe Application Manager : Thank You
LR 5.7 is a perpetual license. Normally you do not need the application manager. But if you had, by chance, trial software installed (or you have a CC product), the application manager is installed and wants to manage your install.
In an other forum entry following the steps as described here helped (that user was also using 5.7): How to convert a Lightroom CC trial to Lightroom 6
Here is the link to the forum entry: Lightroom 5 on new computer
You may also follow this trail: Use the Creative Cloud Cleaner Tool to solve installation problems .
I'm using OS X 10.8.5 as stated in the opening.
The upgrade was initiated from within LR 5.4, not from the site. I don't want the subscription version,
but the perpetual version. Is 5.7.1 the subscription version?
I did move the older version, 5.4, to another folder to prevent LR from overwriting my known good version, just in case.
Perhaps it installed the trial because it did not see a working version?
Daniel
There is no doubt that you need to have the perpetual license version.
What we were saying was that according to the error message you gave, the software thinks to be on a subscription mode.
Your operation to MOVE and not to COPY the older version may have triggered the problem. The question is: Can you start Lr 5.4?
If so, I would COPY Lr 5.4 (to get some protection against overwriting) and start the upgrade again. If you cannot start Lr 5.4 remove 5.7 move or copy 5.4 to the original location and try that out. If it works, install the upgrade again.
I have no idea if that works, but I would try it out. It can't get worse...
The version that was downloaded, I'm sure, was the subscription version. What is odd is, the download was generated within
the paid version. It's as though it was converted to subscription. The Adobe application manager software doesn't even exist
on my computer.
I can use 5.4, it works. I'm glad that I moved it, otherwise I might not have had a working copy at all.
I thought of the same thing, and will try it today.
I guess that there is no way to actually contact Adobe these days? They leave it up to the community to solve their customer's
issues? How brilliant, and frustrating at the same time.
Thanks, Daniel
There are several issues here that need to be addressed. Please note that these are my own findings, as I‘m not an employee nor otherwise connected to Adobe, except that Adobe granted the ACP status to me:
Try correcting the installation, so that the upgrade works as intended. Please let us know about the results.
Now things are getting really weird. I've put back a copy of 5.4 in its original place. Upgraded using the installer that
they provide, and I still get this message:
"Adobe Application Manager, required to start your trial, is missing or damaged.
Please download a new copy of Adobe Application Manager from
http://www.adobe.com/go/applicationmanager."
The really odd thing is it upgraded the 5.4 version that i hid away on another folder called "older versions". It left the one
in the applications folder in tact. It won't even open the software to allow me to enter my license key.
Does anyone know how to get to version 5.7.1 from 5.4? Or is it that I can't get there form here?
Daniel
Quote "Does anyone know how to get to version 5.7.1 from 5.4? Or is it that I can't get there form here?"
Check the link below.
Update information for older versions of Adobe Photoshop Lightroom
I've been down that path, and get the same results.
Every download I try gives me the same disk image: Lightroom_5_CCM_LS11.dmg
Daniel
Quote "Lightroom_5_CCM_LS11.dmg"
And when you run the file describe what happens.
Does it complete as expected?
Do you get an error message?
Are you installing to the default location?
I'm trying to upgrade from LR 5.4 to 5.7.1 I downloaded the installer from within 5.4
and it installs 5.7.1 But when I run 5.7.1 I get the following message:
When I try the link listed in that message, there is no such application on that page.
5.7.1 installs, but I get the message shown above when launching it.
the download gave me this disk image: Lightroom_5_CCM_LS11.dmg
OK so you have LR 5.7.1 installed but it appears to be linked to CC, see if the info in the following article can help you input your LR 5 stand alone serial number. It refers to changing Lightroom CC 2015 from the cloud version to the stand alone application for LR 6 but maybe the same process will allow you to change the LR 5.7.1 version.
Well, I won't be able to do anything from within the app, because it won't run.
5.7.1, that is.
Daniel
If it's installed why does it not run? Do you get an error message when you try to boot the application? What does it say?
I get this:
The link below was provided by Abambo in post 2 in this thread, have you tried the out.
See the screen capture.
You may have to contact Adobe support direct.
Step three seems a little odd: Remove Adobe Lightroom (5.7.1 from web) ? From web? Not sure what to make of that.
My copy is licensed. I was on the chat with Adobe last night for two hours, and still nothing. They transferred me to
their technical "expert", but he simply had me do the same things the first guy told me to do. They told me to come
here to these forums and that the experts here would "revert" me. Not sure that that means, exactly.
Daniel
Lightroom 5.7.1 has been downloaded from the Adobe web site. Lr 5 had been delivered on a disk.
So you could read:
I'm willing to try that. Why not!
I've installed the application manager last night during live chat with adobe--2 hours of my life wasted (but that's another story).
I have a .dmg of LR 5.2 and a license. That should work?
I'll try this, but I don't see how uninstalling the app. manager--or installing it in the first place--should do any good. But, I'll go
along with it for now.
If this doesn't work, I may have to start looking at alternatives to LR. What a shame, I really like the program.
Daniel
Installing creates a known environment, overwriting anything bad that could be left over. Uninstalling removes then that environment and software. It's weird but it could work.
