Hi there
My guess is that the font you used isn't present on the other
machines. There is no way I'm aware of that will allow you to
"embed" your desired font in RoboHelp. The best you can hope for is
to define and use a "Font Set". Basically you declare a list of
fonts that are to be tried. If the first isn't found, the second is
attempted. And so on.
It's normally best to use a font that is known to be present
in various operating systems. For example, Helvetica would cover
the Apple family. Arial or Verdana would cover the PC family and
normally the "catch all" font is specified as Sans-serif.
If you decide to try Font Sets, note that simply declaring
one isn't sufficient. After you declare one, you must then edit
your style sheet to point to the Font Set as opposed to the
individual font.
You mention "Compiled HTML Help". I'm assuming .CHM format
here? I'm not sure if a Font Set would work inside a CHM, but it
may.
Cheers... Rick
