I uploaded an image to be used as a signature In Adobe DC, but I would like to remove/change it to a new image. How do I do that?
You're Welcome! You can also click on the minus sign next to the image to remove the existing image set under Fill & Sign and then click on sign to add an image.
Here is the link which discusses more on this: Fill and sign PDF forms using Adobe Acrobat Fill & Sign
Hi Lm,
As you want to change the uploaded signature image, please refer to the steps given in the following link: Custom Signature Appearances — Digital Signatures Guide for IT
Let us know if you have further question.
Shivam
Thanks. Turns out I had uploaded the image to the "fill and sign" option, and to remove it I cleared my personal settings.
This is not helpful. The minus sign next to my existing signature is grayed out. I have tried restarting Acrobat and the problem persists.
You can click on the plus sign and add a new image.
Hello,
The option seems to be greyed out, however, if you click on the minus sign it will remove the saved signature.
It may take a few seconds to reflect the change.
Please try once and let us know how it goes.
Meenakshi
I am on a Chromebook and using the free version of reader.
I went to sign my first document and I picked image and the image that I used came in but was reversed in colors for the alpha transparency and the black signature lines...
So, I would like to change the image.
I cannot find the file on the chromebook, and I tried to uninstall the app and reinstall, so it seems the app is bringing the image with the account.
How can I delete it or replace it?
Thanx!
Hello,
Thank you for reaching out.
Could you please confirm how exactly you are applying the signature on the document?
Are you using Fill & Sign tool to add the signature?
It would be helpful if you can share a screenshot of the options you are using.
Meenakshi
What if neither of those options work? The minus sign next to the signature is greyed out and if I try to click "Add Initials," it blacks out the screen completey and I have to hi ESC to get rid of it. I've never had this problem before when trying to change signatures but it's getting quite frustrating!
