Hi, I want to make an OAM animation scale responsively in my website. In Dreamweaver I've selected Insert > Animated Composition > selected my OAM file which then gets placed in an <object ...> </object> tag (as an .html file). I've changed the width and height to 100% (and when publishing the OAM file the "make responsive" was checked). But it's not scaling. I tried putting it in an IFrame too and that didn't work. Help, please, Thanks Beth
Is your animation responsive? See Create HTML5 Canvas documents in Animate CC for info on creating responsive animations.
Hi, thank-you for your email. When publishing the animation, I have "Make responsive" checked for "both" (width and height). The animation is not scaling, it displays as the same size on all devises. Do I need to add additional CSS to make it responsive? I've added a Max-width:100% and height:auto to the CSS. Should I delete that?
I am really not sure. I am counting on the other contributors here to help you.
