Our dev team is moving from StarTeam to Team Foundation
Server (TFS) as their source control, and part of that change is to
start adding our full help to TFS (we currently have one project in
StarTeam).
Last week, as a test case, I added our "main" project (the
one that produces our empty master file CHM that links to all the
content CHMs) and had not problem. Today, however, I tried adding
two of our regular projects and received an error stating that one
of the subfolders ("$WWAssociativeLinks") contains an "$" at the
beginning of a path component.
The error message states we need to remove this "$" and try
again. TFS stops the upload process.
Is there any way of renaming these folders? We also have a
"$WWKeywordLinks" folder in most of our projects, which I assume
will also create the same error. Or is this a setting that needs
changing in TFS?
