NEW UPDATE WITH DESTRACTING PURPLE LINE
Oct 18, 2017 Oct 18, 2017
I have now downloaded the new update for Photoshop and with every brush tool stroke I do there is a purple line lagging behind it is does not affect the outcome but I find it very distracting and would like to hear a way to fix that it has to so with the line smoothing feature which I like but unfortunately have to turn it off due to the visual edition to come along with it
2.4K
Community Expert , Oct 18, 2017 Oct 18, 2017
Hi
Preferences > Cursors > "Show brush leash while smoothing" (check it or uncheck it as required)
Dave
Adobe
Adobe Employee ,
Hi Orchibald,
That purple line depicts smoothing of brush strokes you can remove that line by decreasing the smoothing from the options bar on top.
Sahil
thank you for taking your time and answering, but I do want line smoothing and am asking if there is a way to have it with out the purple line trailing it
I have the same issue. The only difference is that my purple bar is 3 inches long and is painting at the base of it, and not where the cursor is.
Nothing I look at or reset is having any impact on this.
It look like Adobe is trying to add Lazy Nezumi Pro type brush smoothing look at the smoothing and the setting icon in the tools option bar for the brush tool.
JJMack
Hi
Dave
Thanks to you both for the reply's, but while that does remove the purple line the tool itself is still drawing 3 inches vertically below where the stylus is pressing. Not having this issue with any other software.
What type of pen are you using. My Wacom intuos pen works correctly are you using Windows or Mac are you having the OS scale your mouse cursor or display.  Does you Pen software have any kind of mapping or calibration like used on screen devices like a cintiq or surface display?
JJMack
Oct 19, 2017 Oct 19, 2017
Thanks for the reply but I found out this morning what was causing it. I had 1 of my monitors in portrait mode, and as soon as I moved it back to landscape it started working correctly again. No other software did that bar Photoshop. So it's a bit of a confusing 1 for me, even turned it back to portrait to make sure it was that and yup that was the culprit.
Very strange.
Many thanks for the reply's though.
Super to know everything is now working as expected. Could you describe your setup exactly, so that one can find the cause of the bug?
PC/MAC? which OS? One or wo external monitors,  what resolutions? plus a Wacom. Is it a Cintiq? which model, and driver?
You should also post on the Wacom forum, and x-post here any progress.
Oct 20, 2017 Oct 20, 2017
where do I find the preferences tab? thank you btw for the answer
On a Windows system Preferences are under the Edit menu
On Mac choose Photoshop >Preferences
Preferences in Photoshop
Dave
