Show 5 replies
1. Image Map Tooltip?
martcol Nov 25, 2008 2:56 AM (in response to Lena P)This looks neat enough and is quite customisable -
2. Re: Image Map Tooltip?
Newsgroup_User Nov 25, 2008 5:12 AM (in response to Lena P)The alt attribute is NOT a tooltip, just so you'll know. It's intended to
be shown ONLY when the visitor has disabled graphics in their browser. IE
is the only browser in the world that ignores this restriction.
Murray --- ICQ 71997575
Adobe Community Expert
(If you *MUST* email me, don't LAUGH when you do so!)
http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
http://www.dwfaq.com - DW FAQs, Tutorials & Resources
"Lena P" <webforumsuser@macromedia.com> wrote in message
news:ggf3s0$pp3$1@forums.macromedia.com...
> I?m trying to find a good way to create image map tooltips that look a bit
> more
> fancy than "alt", or "title" for that matter.
> But I have not been able to find a good way. I understand that there in DW
> is
> Spry tooltip but that does not do it for me. Have found some
> javascripts/DHTML,
> but nothing that works on an image map the way I want. Or maybe it?s just
> me
> that is not able to get it right....
> Maybe someone out there has had the same problem as me and might have a
> good
> "tool"tip that they would like to share? :-)
> / Lena
3. Re: Image Map Tooltip?
Lena P Nov 25, 2008 10:29 AM (in response to martcol)Thank you for the tip.
It seems really nice and configurable. But....I still have this problem.
If you take a look at this link: http://web2d2.com/test/vad.htm and hover over the word "glädje" in the image it looks a bit strange! I am not "man" to find out where the problem is. I have looked in and tried to reconfigure the wz_tooltip.js with no luck.
Any ideas? -
4. Re: Image Map Tooltip?
Newsgroup_User Nov 28, 2008 7:13 AM (in response to martcol)Which DW are you using?
Anyhow, this is certainly wrong -
<map name="leftpic_vadMap" id="leftpic_vadMap">
<area shape="rect" coords="6,6,166,131" href="#"
onMouseOver="TagToTip('Span1', WIDTH, '-300', BGCOLOR, '#CDEAFC', SHADOW,
false, SHADOWCOLOR, '#333333', FOLLOWMOUSE, true)" onMouseOut="UnTip()"
/><span id="Span1"><strong>Glädje</strong><br />All vår verksamhet präglas
av glädje. En positiv känsla av tillfredsställdhet genom lyckade schysta
arrangemang. Framför allt för era medverkande målgrupper (kunder, medlemmar
och personal) men även för er organisation eller företag. </span><!--end
tooltip content -->
</map>
The <span> tag doesn't belong inside a <map> tag. Change that content to
this -
/> </map>
<span id="Span1"><strong>Glädje</strong><br />All vår verksamhet präglas av
tooltip content -->
Also, I have modified your use of this tooltip as follows -
onMouseOver="TagToTip('Span1', WIDTH, '-300', HEIGHT,'-500', PADDING, '0',
TEXTALIGN, 'left', BGCOLOR, '#CDEAFC', SHADOW, false, SHADOWCOLOR,
But you still have the white space showing to the left of the content, and
honestly, I'm not sure why.
If you are using DWCS4, you could try the Spry tooltip.
news:gghg6l$s7i$1@forums.macromedia.com...
> over
> the word "gl?dje" in the image it looks a bit strange! I am not "man" to
> find
> Any ideas?
5. Re: Image Map Tooltip?
Lena P Nov 29, 2008 1:22 AM (in response to Newsgroup_User)Thanks for your help. But now I know what the problem was. In my CSS I had a margin-left in my div at 43px. I corrected it to 0px and everything looks just fine.
/ Lena
