lip sync obsolite
Oct 18, 2017 Oct 18, 2017
Hi. I have an older puppet that I created in illustrator. I decided to revisit this puppet for a project I am working on.
I noticed that beside my lip sync in the record view...I now see a message in brackets (obsolete)
Is there a way to fix my puppet?
Anyone else with this?
493
Adobe Employee , Oct 18, 2017 Oct 18, 2017
The older/obsolete Lip Sync behavior should still work, but if you want to take advantage of the improved Lip Sync behavior and you don't have any recorded takes for the obsolete Lip Sync behavior that you need to retain, you can update to the newer behavior. Just select the puppet in the Project panel, click the menu (three horizontal lines) to the right of the Lip Sync (obsolete) behavior in the Properties panel, choose the Remove Behavior command, then click the "+" button and choose Lip Sync
Adobe Employee ,
The older/obsolete Lip Sync behavior should still work, but if you want to take advantage of the improved Lip Sync behavior and you don't have any recorded takes for the obsolete Lip Sync behavior that you need to retain, you can update to the newer behavior. Just select the puppet in the Project panel, click the menu (three horizontal lines) to the right of the Lip Sync (obsolete) behavior in the Properties panel, choose the Remove Behavior command, then click the "+" button and choose Lip Sync.
THANK YOU!
