i got this error while trying to import a gopro mp4. what should i do?
Which version of the program have you got and on what operating system?
Have you got Quicktime 7 installed?
should i have quicktime installed?
markw41612552 wrote:
..... what should i do?
Provide more detail about what you did to cause the error.
I am using premier elements 15 trial under windows 10
i was using add media menu
i dont have quick time installed
I'm not a GoPro owner. I know little to nothing.
That said, there have been GoPro owners that have had issues due to some GoPro models having a variable frame rate. That is very much unusual for video footage and Premier Elements has had difficulty with it. A fix has been to use software that GoPro provided to change it to a fixed frame rate. One way to check the footage is to use the shareware "MediaInfo". You can also Google for "gopro variable frame rate" and find a variety of discussions.
Good luck. I hope this helps.
Quicktime 7 adds components that may be necessary in order to edit some video formats.
Because the Quicktime Player itself can be a security risk, you can opt to install the components but not the player during installation -- or you can install the whole package and disable the Quicktime Player file by changing its suffix from .exe to .old.
Installing quicktime solved the problem for me!
Please mark this question as correctly answered, martijn.
How? I can't find a button to mark the question as answered. (I am not the 'owner' of the question)
When you post a response to this thread on the Adobe forum, you'll see a Correct Answer button -- like this.
Sorry, button is not available.
You are not on the forum. You are in the forum's Inbox.
Go to Premiere Elements
Martijn is not the original poster therefor cannot set the correct answer.
