Hello all,
Total newbie here with a hopefully simple answer. I am working inside of an adobe form in the run action "coding." I would like to be able to open a PDF file but not to the full screen view, a specified view. I would like it to be resizable once it is opened and maybe a close box but neither of the latter two are necessary.
var aIdentification = "Splitter"
var aSpecs = ["Manufacturer Specs","X.pdf"];
var cRtn = app.popUpMenu(aIdentification,"-", aSpecs);
app.openDoc((cRtn),this);
This code shows a menu when the mouse is over the field in a PDF Form. When I click on the X.PDF, I would like it to open to a smaller window that can hopefully be sized prior to opening. Ive googled for quite a few hours but haven't been able to make sense of what to search for. Can anyone help? Thank you in advance!
Hi there
Unfortunately I believe you are in the wrong forum. I'm not certain where you need to be asking. If I can figure that out, I'll be happy to move this thread to where it needs to go.
What Adobe application are you using?
Cheers... Rick
Adobe acrobat DC I believe it is called. Thank you for helping me. I would imagine it is a simple line of code to set the parameters but like I said, I don't know what question I am asking.
Thread moved here from Adobe RoboHelp forum.
Not possible.
This is Acrobat JavaScript. A very large collection of methods and properties. Do you have Adobe's JavaScript reference? Most things won't come up in Google.
I do not have the reference, if I did, what would I be researching? I am not a coder in any way, just learning some things so I can complete a project but like I said, I'm amazed I've gotten it to work this far with the little examples I have found on the net
Actually, you are a coder, because you're coding. The more you try the better you get... ! But you have been told, and I tend to agree, that this can't be done. But read on if you want to know more.
The way to use the Acrobat JavaScript Reference, which is about 800 pages, is either to dip into it, exploring deeply, or read it from beginning to end. This is the sort of thing coders love. Or get to love. Or have to put up with. Searching google for snippets won't cut it, not with Acrobat... Here's an old one, but still pretty much relevant: https://www.adobe.com/content/dam/acom/en/devnet/acrobat/pdfs/js_api_reference.pdf
im just reaching now, could I open the file in internet explorer or another environment that would yield the same result? ill drop it if not, just reaching.
