Hi folks,
I've just started using Lightroom CC on Desktop and iPhone. I want to avoid using my phone's storage with photos, but when I delete them from the mobile, they are deleted from the Desktop app too. I can't find a way to stop this happening. Can anyone help?
best,
Paul Bradforth
Tap the LR icon top left, go to Local Storage and hit Clear Cache. It only caches low res versions on your phone, and downloads them from the cloud as they're needed, so you shouldn't find it takes up too much space.
Thanks Victoria—I've just done that, but what if I have hundreds, or even thousands of photos? Surely even the low res versions will take up some space?
Also, I've just read on one site (I've forgotten where) that once LightroomCC on the Desktop has synced, you can delete the phone photos and the downloaded ones will remain safe in the Desktop app?
best,
Paul
That's Lightroom Classic, you read about. Don't do that with Lightroom CC.
You can see how much space it's taking on your phone in that same Local Storage screen. I have 60512 photos in the cloud at the moment, taking up 600GB of cloud space, and that's using less than 1GB on my phone right now.
Victoria, is that the figure under 'Cached Files' or 'Locally stored copies'? Also, are your photos RAW or jpgs?
Paul
That's both combined, and most photos are raw.
Thanks Victoria; I'll stop bothering you soon, just one more:
Under 'Locally stored copies', I have 1.37GB. Under 'Cached Files' I have 0.02GB. Am I right to assume that the 1.37GB is what is stored in the Cloud, and the 0.02GB is proxies being stored on the phone because I clicked them to see bigger versions?
I don't remember how they define which goes in which, but that's all stuff stored on your phone right now. Go back a level and select Cloud Storage to see how much cloud space is used.
Available Cloud Storage is 19GB of 20GB. Seems a bit excessive for 48 photos, many of which are jpgs…
19GB available sounds ok! It's rounded off too, it's not exactly 19.
Fair enough 🙂 I'll see what happens over the next few days. Thanks for your help!
best,
Paul
Useful thread.
Use case:
LR CC Classic hosted images on my MacBook Pro
Question - Do I now need to delete these cloud copies? How am I certain that this will not synch back and remove them from LR CC C.
Question - What if I edit a phone version and an LR CC C version and the RESYNCH
Feature - Synch and keep on cloud or Synch and remove from cloud
Sub use case
Following from use case above, I attempted to delete an orphaned, now non-synched image from my phone
Received a warning that this would delete the image from cloud (got it) and all synched (there are none) locations. OK so far.
Fine, but if I click to resync this folder on LR CC C will it then delete the image from LR CC C?
Use case:
Question - Do I need to copy these to another folder on LR CC C to be certain that they don't go away? Will that create two images?
Question - Why can't I synch a dynamic catalog (smart catalog)?
