Will the new Lightroom Support the Nik software plugins?
No not at present. You would need Lr Classic or Photoshop to run plug-ins.
That's an interesting question. Not sure how that would be accomplished unless on the desktop version only. Not sure it would would work with Mobile and web based versions.
Hi, this is very disappointing as I have purchased Lightroom CC and edit all my images in silver efex pro. Do you know if this is likely to change soon or should I just change my subscription to Lightroom Classic.
LR Classic seems to work but Photoshop Classic doesn't seem to work.
Did you know that most (all?) of the NIK (plugins) will work as 'Stand-alone' software?
If you Save your edited image to the hard-drive as a JPG- From Lightroom-CC,
Save your photos to a hard drive or share on Facebook
You can then simply-
1. Start NIK Silver Efex
2. [Ctrl+O] or Menu File > Open
3. Edit with Nik and [Save image as...]
(Note: open a Copy or do 'Save Image as...' because 'Save' will over-write the file that you open.)
Nik does not put links in the Start menu or desktop icons, but it is easy to find the program (in Windows - Silver Efex Pro2 64bit) and add a link to the Start page or the Task bar.
