.chproj file is 0 bytes, cant import into after effects
Oct 19, 2017 Oct 19, 2017
Hello, I produce a youtube show where I use character animator to animate puppets of a freind and I that provide commentary
heres an example
Sega Racers for DOS - Sega Races to the bottom - Game Pulp Adventures - YouTube
Normally I record the puppet performances in character animator and then import them into after effects to composit them with other elements,  however with the new non beta character animator, the .chproj files that were produced, the ones with our performances, and the ones that I usually import into after effects directly, are now 0 bytes, and after effects simply says 'the project could not be opened'
is there something Im missing here? Has anybody else had this issue?
thank you
2.1K
Adobe Employee ,
A Character Animator project is the folder itself that contains the .chproj file and the Ch Data and Ch Media subfolders that contain the actual data. The .chproj file has always been 0 bytes -- it's mainly there so you can double-click or select something when importing. Do you have those Ch Data and Ch Media subfolders next to your .chproj file?
When you import into After Effects (via AE's Import File dialog box or by dragging the .chproj into AE's Project panel), it should initiate a Dynamic Link connection and open the Import Character Animator Scene dialog box so you can select the scene to import.
Do you also have the latest After Effects CC (i.e., version 15.0, Adobe After Effects CC 2018 in the title bar) installed, too?
Ah it would seem that for some reason when I told CC to update everything, it did,...except for after effects. That is probably it and now I feel dumb. Updating (again) now and hopefully thatll fix it
Thank you so much
Jun 23, 2018 Jun 23, 2018
Hello, I understand that the .chproj files are 0 bytes, but I'm trying to send them by e-mail, but I can't because for the computer it's "an empty file"
There's any solution?
I tried compessing the file and send it, but the person who received it told me there was nothing on the file.
Adobe Employee ,
The project is the entire folder that the .chproj file is in, so you'll need to archive (.zip) the folder that contains the .chproj, Ch Data, and Ch Media subfolders, and send that .zip file. Hope this helps.
Mar 12, 2018 Mar 12, 2018
I also have the same problem. I have 2 project files and all of them became 0 bytes after my computer shutdown unexpectedly.
Mar 13, 2018 Mar 13, 2018
I too have the same problem.All of my files had become 0 bytes. What should we do now.I can't import to CH..
Adobe Employee ,
Did the information in my Oct 19, 2017 reply help? Note that .chproj files are always 0 bytes. It's the Ch Data subfolder next to it that contains the actual project data. A Character Animator project is a folder that contains the .chproj file, Ch Data subfolder, and Ch Media subfolder.
If you're trying to use a CH scene in AE, it's easier to just drag the scene from CH's Project panel into AE's Project panel.
Mar 14, 2018 Mar 14, 2018
when i try to encode that .chproj  file in media encoder, its not working. dynamic link error.
while opening .chproj files  in CH files are copying but there's nothing at there.
Adobe Employee ,
Mar 15, 2018 Mar 15, 2018
Do you have the latest installed version of Character Animator and Adobe Media Encoder? If so, from Character Animator, if you open the scene, then choose File > Export > Video via Adobe Media Encoder, it should work that way. No need to try to import the .chproj file directly and select a scene.
