Ok so I have been working on a tool that will automate some file changes for me. Thank you to itsBenMason it has been coming along awesome. So now I have 2 tasks left. Task one....
I am searching folders for any files that contain _matte.eps
var files = dir.getFiles("*_matte.eps");
var folderFiles = folder.getFiles("*_matte.eps");
How can I make this look for *_matte.eps as well as *_gloss.eps?
Task two....
These are already .eps files. How do I just save the file overwriting the .eps that I have made changes to?
I have tried both of the following formats:
doc.save(SaveOptions.SAVECHANGES);
doc.save();
Both of those save a .ai file with the same file name as the .eps
Here is the code in it's entirety... Any help would be appreciated!
// Establish variable to count changes made
var changesMade = 0;
// Display the GUI
try {
var gui = createGUI();
gui.show();
} catch (e) {
alert(e);
// Go through subfolders as well
function getSubFolders(dir, collection) {
if (collection === undefined) collection = [];
var files = dir.getFiles();
if (files.length > 0) {
for (var i = 0; i < files.length; i++) {
var file = files;
if (file.constructor == Folder && file.name !== "") {
collection.push(file);
getSubFolders(file, collection);
alert(file.name);
return collection;
// Panel fields and information
function createGUI() {
var gui = new Window("dialog", "CMYK Correction Tool");
gui.alignChilren = ["fill", "fill"];
gui.orientation = "column";
var panelGroup = createGroup(gui, "row");
// Wrong CMYK
var wrongPanel = createPanel(panelGroup, "Wrong CMYK Values");
var wrongCyan = createTextField(wrongPanel, "Cyan Value:", "");
var wrongMagenta = createTextField(wrongPanel, "Magenta Value:", "");
var wrongYellow = createTextField(wrongPanel, "Yellow Value:", "");
var wrongBlack = createTextField(wrongPanel, "Black Value:", "");
// Right CMYK
var rightPanel = createPanel(panelGroup, "Right CMYK Values");
var rightCyan = createTextField(rightPanel, "Cyan Value:", "");
var rightMagenta = createTextField(rightPanel, "Magenta Value:", "");
var rightYellow = createTextField(rightPanel, "Yellow Value:", "");
var rightBlack = createTextField(rightPanel, "Black Value:", "");
var buttons = createGroup(gui, "row");
// Confirm button
var confirmBtn = createButton(buttons, "Confirm", function() {
try {
// Select folder that contains your files
var dir = Folder.selectDialog("Select your file directory...");
if (dir != null) {
//Get all sub folders
var folders = getSubFolders(dir, []);
//Loop over folders
for (var i = 0; i < folders.length; i++) {
var folder = folders;
// Only look for files with the .ai extension and collect them
for (var j = 0; j < folderFiles.length; j++) {
files.push(folderFiles
//Loop over files
// alert(files.length);
var file = files;
if (file.constructor == File) {
var doc = app.open(file);
// Collect all of the open document pathItems
var allPaths = doc.pathItems;
// Loop through all of the open document pathItems
for (var z = 0; z < allPaths.length; z++) {
// Only look for a specific CMYK fillColor
if (Math.round(allPaths
.fillColor.cyan) == getText(wrongCyan) && Math.round(allPaths
.fillColor.magenta) == getText(wrongMagenta) && Math.round(allPaths
.fillColor.yellow) == getText(wrongYellow) && Math.round(allPaths
.fillColor.black) == getText(wrongBlack)) { */
.fillColor.cyan).toFixed(2) == Math.round(getText(wrongCyan)).toFixed(2) && Math.round(allPaths
.fillColor.magenta).toFixed(2) == Math.round(getText(wrongMagenta)).toFixed(2) && Math.round(allPaths
.fillColor.yellow).toFixed(2) == Math.round(getText(wrongYellow)).toFixed(2) && Math.round(allPaths
.fillColor.black).toFixed(2) == Math.round(getText(wrongBlack)).toFixed(2)) { // Change the fillColor properties
allPaths
.fillColor.cyan = getText(rightCyan); allPaths
.fillColor.magenta = getText(rightMagenta); allPaths
.fillColor.yellow = getText(rightYellow); allPaths
.fillColor.black = getText(rightBlack); changesMade++;
doc.save();
// Close the document
doc.close();
gui.close();
} catch (e) {
alert(e);
// Cancel Button
var cancelBtn = createButton(buttons, "Cancel", function() {
gui.close();
return gui;
// Function to collect user input
function getText(field) {
return field.text !== undefined ? field.text : "";
// Function to build panel
function createPanel(parent, title) {
// Create Panel
var panel = parent.add("panel", undefined, title);
panel.orientation = "column";
// Return panel
return panel;
// Function to create button
function createButton(parent, title, onClick) {
// Create Button
var button = parent.add("button", undefined, title);
if (onClick !== undefined) button.onClick = onClick;
// Return button
return button;
// Function to create field in panel
function createTextField(parent, title, content) {
// Create a group for title and field
var group = createGroup(parent, "column");
group.alignChildren = 'left';
// Create title
var title = group.add("statictext", undefined, title);
var field = group.add("edittext", undefined, content);
field.preferredSize = [200, 23];
// Return the field as its all you'll use
return field;
// Function to organize the panel layout
function createGroup(parent, orientation) {
// Create Group
var group = parent.add("group");
group.orientation = orientation;
// Return Group
return group;
alert(changesMade + " color changes were made.");
Try this
function saveEPS(doc, file) {
//Create save options
var options = new EPSSaveOptions();//Save
doc.saveAs(file, options);
}function getFiles(folder) {
return folder.getFiles(/(_matte|_gloss)\.eps/i);
}getFiles(new Folder("Path/To/Files/"));
so here is the error I get when I run the following script.... what am I doing wrong?? and it isn't saving over the eps file.
// Display the GUI
try {
gui.show();
} catch (e) {
alert(e);
var file = files;
alert(file.name);
return collection;
// Wrong CMYK
// Right CMYK
// Confirm button
try {
if (dir != null) {
getFiles();
//var files = dir.getFiles("*_matte.eps");
//Loop over folders
// var folderFiles = folder.getFiles("*_matte.eps");
//Loop over files
var file = files;
allPaths
//doc.save();
saveEPS();
doc.close();
gui.close();
} catch (e) {
alert(e);
// Cancel Button
gui.close();
return gui;
// Create Panel
// Return panel
return panel;
// Create Button
// Return button
return button;
// Create title
return field;
// Create Group
// Return Group
return group;
//Save
//getFiles(new Folder("Path/To/Files/"));
change
saveEPS();
to saveEPS(doc, file);
same error
in the save EPS function add
alert(doc);
alert(file);
and see what it outputs.
Not able to open atom or anything at the minute so can only guide you through until i can.
Just noticed you have this
getFiles();
but you are not setting any var with the returned files
and also the getFiles() function takes a folder object
- function getFiles(folder) {
- return folder.getFiles(/(_matte|_gloss)\.eps/i);
Ok. No worries. Again I appreciate all your help. I am not a programmer... I kinda sorta get by with basics. But I am drowning here in all your efficient functions lol.
So what I am working toward is allowing the user to put in the correct and incorrect values.
If the file contains the name _gloss.eps it gets the following CMYK values (which I want the user to be able to type in).
CORRECT values for CMYK gloss:
CMYK Gloss: C 0 M 100 Y 100 K 35
If the file contains the name _matte.eps it gets the following CMYK values (which I want the user to be able to type in).
CORRECT values for CMYK matte:
CMYK Matte: C 0 M 100 Y 100 K 33
No matter if it contains _matte.eps or _gloss.eps the incorrect values are the same (which I want the user to be able to type in).
INCORRECT values for CMYK gloss AND CMYK matte:
C 22.98 M 100 Y 100 K 17.84
All files I need to edit will be .eps. I want the changes to be saved to the edited .eps file (with no new file created).
All of this I would like to apply to a selected folder and all subfolder/subfiles.
What we have here is really close...but it is getting over my head with all the functions.
