Hello!
I would like that when the user presses the Enter key, it presses the button called "Export" in my script.
Or if I could just know when the player presses Enter to call a function that would work too.
Here's the script I'm trying to use it for (javascript), it exports PNG's from all the groups in your active document. If someone's interested:
// for saving files
var doc = app.activeDocument;
var Path = doc.path; // set the .png next to .psd
//Path = "~/Desktop/test"; // personal folder
Path = "D:\\GameDevelopment";
var Name = doc.name.replace(/\.[^\.]+$/, '');
var Prefix = "PROP_";
var Suffix = "";
// AUTOMATIC OPTIONS <= CHANGE HERE
var x = 512;
var y = 512;
var ActivateBlur = true;
var BlurStrength = 10;
var saveFile = File(Path + "/" + Name + Suffix + ".jpg");
// AUTO OPTIONS
var dlg = new Window('dialog', 'PNG Batch Save');
dlg.onEnterKey = function() { Algorithm();};
var G1 = dlg.add('group', undefined);
dlg.msgSt = G1.add('statictext', undefined,
'Path:');
dlg.addEventListener('enterKey', Algorithm);
dlg.msgSt.alignment = [ScriptUI.Alignment.LEFT,
ScriptUI.Alignment.TOP]
dlg.msgEt = G1.add('edittext', [0,0,400,20],
Path, {name: "path",multiline:false,noecho:false,readonly:false});
// Resolution UI
dlg.msgPnl = dlg.add('panel', undefined, 'Resolution');
dlg.msgPnl.orientation = "row";
dlg.titleSt = dlg.msgPnl.add('statictext', undefined,
'X:');
dlg.titleEt = dlg.msgPnl.add('edittext', undefined,
x, {name: "x"});
'Y:');
y, {name: "y"});
// Blur UI
dlg.msgPnl = dlg.add('panel', undefined, 'Blurred');
dlg.hasBtnsCb = dlg.msgPnl.add('checkbox', undefined,
'+ Blurred Version', {name:"isBlur"});
dlg.msgSt = dlg.msgPnl.add('edittext', undefined,
BlurStrength, {name:"blurStrength"});
dlg.hasBtnsCb.value = ActivateBlur;
ActivateBlur = dlg.hasBtnsCb.value;
// Buttons UI
dlg.btnPnl = dlg.add('panel', undefined, 'Save');
dlg.btnPnl.buildBtn = dlg.btnPnl.add('button', undefined, 'Export');
dlg.btnPnl.buildBtn.addEventListener('click', Algorithm);
dlg.btnPnl.onClick = Algorithm;
dlg.btnPnl.buildBtn = dlg.btnPnl.add('button', undefined, 'Cancel');
dlg.show();
// Algorithm must be called when clicking on Export button
function Algorithm()
GetUIValues();
dlg.close();
// need an array to know which grp was on or off
var oldLayers = new Array();
for (var i = 0; i < doc.layerSets.length; i++) {
if (doc.layerSets.visible == true) {
oldLayers.push(1);
if (doc.layerSets.visible == false) {
oldLayers.push(0); // not visible
// set all groups off
doc.layerSets.visible = false;
// if the layer used to be visible
if (oldLayers == 1) {
//alert("Found a visible grp!");
// we set it visible
doc.layerSets.visible = true;
TrimResizeAndSave(doc.layerSets);
if (ActivateBlur) CreateBlurredVersion(doc.layerSets);
// we set it invisible again
// set whichever groups were originally on visible again
if (oldLayers == 1)
function GetUIValues() {
//alert(dlg.findElement("x").text);
x = dlg.findElement("x").text;
//alert(dlg.findElement("y").text);
y = dlg.findElement("y").text;
//alert(dlg.findElement("blurStrength").text);
BlurStrength = dlg.findElement("blurStrength").text;
//alert(dlg.findElement("isBlur").value);
ActivateBlur = dlg.findElement("isBlur").value;
Path = dlg.findElement("path").text;
var c = /\\/g;
if (Path.match(c)) {
//~ alert("found \\");
Path = Path.replace(c, "/");
c = ':';
if (Path.match(c )) {
//~ alert("found :");
Path = Path.replace(c , '');
Path = "/" + Path;
function SaveJPEG(saveFile, jpegQuality) {
jpgSaveOptions = new JPEGSaveOptions();
jpgSaveOptions.embedColorProfile = true;
jpgSaveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
jpgSaveOptions.matte = MatteType.NONE;
jpgSaveOptions.quality = jpegQuality;
activeDocument.saveAs(saveFile, jpgSaveOptions, true, Extension.LOWERCASE);
function SavePNG(saveFile) {
pngSaveOptions = new PNGSaveOptions(9, false);
activeDocument.saveAs(saveFile, pngSaveOptions, true, Extension.LOWERCASE);
function TrimResizeAndSave(group) {
var savedState = doc.activeHistoryState;
// trim
doc.trim(TrimType.TRANSPARENT, true, true, true, true);
// resize algorithm
if (doc.height > doc.width) {
doc.resizeImage(null, UnitValue(y, "px"), null, ResampleMethod.AUTOMATIC);
else {
doc.resizeImage(UnitValue(x, "px"), null, null, ResampleMethod.AUTOMATIC);
// we save the ouput
saveFile = File(Path + "/" + Prefix + group.name + Suffix + ".png");
SavePNG(saveFile);
doc.activeHistoryState = savedState;
function CreateBlurredVersion(group)
// trim
// resize algorithm
else {
// blurred output
var blurredPath = File(Path + "/" + "BLURRED_" + Prefix + group.name + Suffix + ".png");
// transform document to smart object
var result = createSmartObject(group);
result.applyGaussianBlur(BlurStrength, BlurStrength);
// save
SavePNG(blurredPath);
// create smartobject from specified layer or layerSet/group
function createSmartObject(layer)
var layer = layer != undefined ? layer : doc.activeLayer;
if(doc.activeLayer != layer) doc.activeLayer = layer;
try
var idnewPlacedLayer = stringIDToTypeID( "newPlacedLayer" );
executeAction( idnewPlacedLayer, undefined, DialogModes.NO );
return doc.activeLayer;
catch(e)
return undefined;
}// JavaScript Document
you need to activate some element in dialog.
insert one more line like this
dlg.msgEt.active = true;
before line with dlg.show() insert such code
function key_handle(e)
switch (e.keyIdentifier)
case "Enter":
dlg.btnPnl.buildBtn.notify();
break;
dlg.addEventListener ("keydown", key_handle, false);
Thanks for helping me out r-bin!
I did as you suggested but it doesn't work, am I doing it wrong?
// Buttons UI
case "Enter":
break;
dlg.show();
Thanks that did it! Have a good day and thanks again!
