I've been going through a lot of burning hoops to migrate my old LR5 catalog to CC.
Here's an outline of what I've done so far:
* Used to have LR5 catalog on a NAS drive
* CC refused to migrate said catalog because it was too old
* Installed Classic trial version and tried to upgrade catalog
* Classic refused to migrate since catalog was on a network drive
* Copied catalog to a USB drive (of course there were corrupt files which threw off Finder)
* Finally started CC, stated migration
* CC refused to migrate because there were too little disk space available
* After realizing I won't be able to free up enough space (have 128GB Macbook Pro) I see it's possible to change location in CC to a custom location. Set this to a new folder on the same USB drive as before
So, the problem now is that CC starts migrating and then fails saying "Not enough space on main volume" - but I asked it to use an external disk?!
Can anyone tell me what I'm doing wrong?
You've taken the right initial steps; directing Lightroom CC storage to an external drive with lots of space is the right first step. However, while migrating the Lightroom Classic catalog, Lightroom CC also creates a database and previews on your local hard drive to enable viewing and editing your images during migration. This can take up significant additional space, which can be as much as 20% of the size of your catalog and original files. Especially when migrating large catalogs, make su
...Copy link to clipboard
It's most likely the cloud space you are running out of not your local space. Click on the cloud icon at the top right of LR CC and confirm you still have cloud storage space.
No, I'm just getting started. It says 0 bytes of 1 TB used and my photo library is 3-400 GB. The migration only runs for a few seconds before it stops.
I think you’ll need over 400GB of free space at the chosen location to migrate.
That's not a problem if Lightroom actually used the space I asked it to. I changed the location to my USB drive which has 1.5+ TB of free space but it complains that I don't have 50 GB available on my main drive.
Did you set the location in LrCC?
Yes I did. The funny thing is that the custom location points to the external USB drive (as expected) but above it says there's not too much available space on my internal disk and there's a slider I can use to configure how much of the library to sync to local disk. I would expect this to reference the USB drive, too.
Either this is a bug in CC or I'm misunderstanding how this is supposed to work.
Sounds like a bug indeed. It should move everything to the external drive if you change this setting.
Any resolution to this? I'm having the exact same problem (after following the exact same steps — although I was starting with an LR4 catalog).
Same issue where I change the location to a USB drive, but then tells me there's not enough space on my main drive.
No resolution. I actually got the migration going, but I presume that was because I accidentally managed to free up enough space on my main drive. However, the migration hung at 10% for many hours with no disk or network activity so I stopped it.
This is really disappointing and I feel like I'm throwing money out the window. Neither can I find any place to report bugs. Can I assume Adobe is reading this and consider it a bug report?
No. Unfortunately few Adobe people read posts here. This is a User-2-user
forum. You should post it at feedback.photoshop.com. ACP people you see
here are just volunteers.
On Mon, Oct 23, 2017 at 10:20 AM, riccof1994239 <forums_noreply@adobe.com>
You've taken the right initial steps; directing Lightroom CC storage to an external drive with lots of space is the right first step. However, while migrating the Lightroom Classic catalog, Lightroom CC also creates a database and previews on your local hard drive to enable viewing and editing your images during migration. This can take up significant additional space, which can be as much as 20% of the size of your catalog and original files. Especially when migrating large catalogs, make sure you have that amount of free space on your local drive.
Becky
Hi Becky,
Is it possible to have Lightroom CC use a different local drive? My setup is I have two internal drives, C:\ which is a 64GB SSD and D:\ wich is a 2TB HD. Lightroom CC tells me "Note enough space on main volume, Lightroom CC needs enough space (106.68 GB on Windows) to store previews and catalog info."
I need to be able to direct Lightroom CC to use my internal D:\ drive where I have plenty of space. If it can only work on the internal C:\ drive I can't even free up the required space it says it needs.
Currently, you can specify a different drive to store originals. The previews and catalog need space on the main drive.
There were some changes and fixes related to Local Storage with the Lightroom CC 1.1 update, which went live last night. I think it is now easier to understand what kind of space the product needs on the local drive. Take a look and report back whether this helps your specific situation.
Becky
Migrate photos and videos from Lightroom Classic CC to Lightroom CC
May be of interest
this is could be related?
did you ever figure this out? I have nearly 200K photos in my library--I will NEVER have 20% of that available space on my HD. Is this really this hard?
Have you looked at the changes in local storage preferences in the 1.1 release? It should show clearly what space is required and allow you to specify how much space you want to designate to your photo cache. The required space is the only piece of this that you cannot adjust, and it's a fairly small piece compared to the default size of your photo cache (20%). You can make your photo cache any size you want, down to 0%. Just note, the smaller the photo cache, the fewer originals and previews Lightroom keeps locally for you. Further, you can still specify an external drive for your original storage if you like.
