Since upgrading to Photoshop 2018, I'm unable to change the leading of any of my text. This is a HUGE problem that wasn't there in the previous version. This seems to happen more on documents I had saved in the previous version of PS...less on new documents...but it's still a huge problem.
I should clarify...I AM able to change the leading by using the pulldown menu, however if I want to enter a custom value (which I DO!), it keeps defaulting back to 8.73pt...no matter WHAT I do or what size text I am using.
Needless to say, this is SUPER AGGRAVATING!! Does anyone else have this problem....or a solution to it?
Thanks in advance for any help you can provide!!
BTW...I'm running Photoshop on an iMac 27" with loads of RAM and the latest OS installed...in case that helps.
A couple of comments:
First , there is a workaround to your issue:
It looks like you may have the same problem as in this thread. It affects text that has been transformed:
Photoshop CC 2018 - line spacing tool failoure
If so, it is a bug that has been acknowledged and the following workaround should get you going.
a. Enter the leading value in the Properties panel.
b. When you hit enter the value in the properties panel box will change to something different (that is a bug) but will now show correct
...Copy link to clipboard
Hi Cyprogirl,
This is a known issue and has been logged as a Bug, our team is aware of this and is working on a fix for the same.
Sahil
Thank you for getting back to me Sahil. I really appreciate it, and hope a fix is out SOON! I really hate to say this, but in my opinion, this version of the software should never have been released without a LOT more testing. It's buggy as all get-out, in MULTIPLE ways!!! I'm having trouble with SOOOO many aspects of Photoshop now...that I NEVER did before!! I really wish I hadn't downloaded this software...it's been nothing but trouble, and now I can't go back to the previous version. It's extremely frustrating, to say the least.
b. When you hit enter the value in the properties panel box will change to something different (that is a bug) but will now show correctly in the Character panel
c. The value applied to the text will be the same as you entered and now shown in the character panel
Note : The workaround does not work backwards - you must enter in the properties box.
Second
You say you cannot go back to the previous version - you can. You can have older versions installed alongside the latest version (I have three versions installed here)
To do that go to the CC app - click the down arrow next to Photoshop and choose "Other versions"
Dave
Thanks Dave...super helpful!!
It appears this issue is resolved with the latest release.
