Hey guys!
I recently updated to CC 2018 and I've noticed shift+CTRL+Z randomly stops working. It's a huge inconvenience in my workflow while illustrating.
Is anyone having this issue? I use the keyboard shortcut and sometimes it works, sometimes it doesn't. I have to re-click the canvas (even though I haven't unclicked it) for it to undo. It's super cumbersome and it's driving me a bit nuts.
The only thing that's changed in my workflow is PS. I'm using a Wacom cintiq 13HD with Windows 10. But again, nothing in my workflow has changed, software/hardware.
Hi All,
This issue should be resolved in Photoshop 19.0.1
If you don't see the Photoshop update in your Creative Cloud application, then click in flyout in upper right corner and choose "Check for App Updates".
Please let us know if you continue to see this issue in the new version.
Thanks for your patience.
Akash
Came here because I'm having the same problem, very frustrating. It's like I have to press them in a certain order for it to work wheras before I could just hit all three. It's hard to explain but I have to retry to undo constantly now
Yeah it's so strange. Even right clicking with my pen doesn't seem to register?
And I literally just got my first ever Photoshop crash/not responding of my life. Sigh 😕
I'll just revert back to CC 2017.
If you re-install/update the Wacom drivers that should hopefully sort out your right click issue. The latest drivers came out on the 19th. The upper of the two side buttons on my pen stopped working until I did. I've now set this button to undo
Not a fix, but a workaround is to press Ctrl+Z for your first undo, then you can Ctrl+Alt+Z following.
None of my ALT shortcuts are working. This is ridiculous.
Similar problem here - I have a 3 monitor setup and used a shortcut ALT+CTRL+1 to load a workspace for the 3 monitors (I have several shortcuts programmed into a Cherry programmable keypad so I actually only have to hit a single key). With CC 2017 I could hit the CTRL and ALT keys in any order but now, with 2018, I have to hit the CTRL key first. Of course sod's law decreed that I had it wrong way round in the keypad.
Hi DavidRobot,
We have logged this issue as a bug and our engineering team closely working on this issue to get it fix asap.
You can refer the feedback link for the same.
Alt-Backspace taking two hits to work? CC 2018 | Photoshop Family Customer Community
Mohit
Hi All,
Akash
Hey there.
the problem just popped up out of nowhere yesterday:
i was drawing and out of a suddon i couldn't use my shortcut undo (alt+ctrl+z) via my wacom pen.
Now i just updated and i just noticed that eventhough i have a subscription, my newest version i can update to is V 19.0 (?!)
You are referring to 19.0.1
I am running a Photoshop in german, does this have anything to do with it (well i couldn't imagine that, but i just want to drop this)
Anyhow:
I NEED MY UNDO VIA MY PEN(!) PLEASE HELP ME!
(the rest of the features of CC18 is great bytheway!)
Best,
Max
Hi mightymax,
Photoshop displaying the incorrect version name after the 19.0.1 update and we have identified this issue. Please refer the below article to check the correct version of Photoshop.
Photoshop Version Displayed Incorrectly
Mohit
Hey Mohit,
thanks for the very fast reply, i really apprechiate this.
i do have 19.0.1 installed.
Unfortunately my stylus of my cintiq 27" wacom can't fire a alt+cmd*z via my penbutton anymore...
So my problem is still on:-/
I am experiencing difficulty with my ctrl+alt+z in version 20.0.01. Where I used to toggle with ctrl+z, now it behaves like ctrl+al+z in undoing each previous change. And my ctrl+alt+z is toggling. This is a huge annoyance as I have been using the shortcut since version CS5. I'm also having trouble with my delete button when using a text tool. I can't delete several characters by holding down the delete button as I used to, but rather, I have to repeatedly press the delete key for each character I want to erase. I have tried these functions in other programs like word and notepad and they work fine. Please help!
Running Windows 10 Pro on a Dell Precision with Intel xeon processor
Still not fixed!!
Hey Akash, I was just wondering about this same issue on older versions of Photoshop. Im running the latest version of CC 2017 on a Windows 10 Asus laptop. I can give more specifics once I am back to my machine but this issue just randomly popped up.
I am not running Photoshop 2018 because there were too many freezing issues on my machine and for these reasons I am hesitant to run 2019 (which is why I downgraded to the last known working/ stable version- CC 02017).
I was wondering if you could answer to this occurring in the 2017 versions so that I do not have to upgrade until 2019 proves to be ubiquitous and stable among other Photoshop CC subscribers.
Thank you,
-Jon LaFerriere
