Ashburton wrote:
> I'm relatively new to using cftransaction but I've come
across something that I
> can't explain. I added "SET autocommit=0;" to the
connection string of my
> database in CFAdmin for a MySQL 4.1 database and
restarted the service. The db
> is using the native MySQL 4/5 driver.
> In the code attached below and found that if I remove
the <cfif commitData>
> logic the data is still written to the tables. If I
force an db error on the
> second insert the data appears to roll back and not
write to either table. If I
> remove the cftransaction rollback statement it will
write the first insert but
> not write the second.
> So, even with autocommit switched off (if I actually do
have it switched off)
I think that autocommit is switched off only for the first
transaction.
Here's a log of the commands submitted to the MySQL server
for a
transaction:
1 Query SET NAMES utf8
1 Query SET character_set_results = NULL
1 Query SET autocommit=1
1 Query SET
sql_mode='STRICT_ALL_TABLES,NO_ZERO_IN_DATE,NO_ZERO_DATE,ERROR_FOR_DIVISION_BY_ZERO,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION,STRICT_TRANS_TABLES'
1 Query SET SESSION TRANSACTION ISOLATION LEVEL
READ COMMITTED
1 Query SET autocommit=0
1 Query SELECT @@session.tx_isolation
1 Query QUERY1
1 Query QUERY2
1 Query commit
READ COMMITTED
READ COMMITTED
You can see that autocommit=0 is executed once at the start
of the
connection and it's set to 1 after the transaction is
commited.
This is the code that I used (CF performs an automatic commit
when it
reaches the </cftransaction> tag, regardless of the
value of the
autocommit variable):
<cftransaction action = "begin">
<cfquery datasource="ds">
QUERY1
</cfquery>
QUERY2
</cfquery>
</cftransaction>
Mack
