This is my first attempt to obtain a solution to my problem with installing Acrobat Pro 9 as part of Adobe Creative Suite 4.
I have spent several months with Adobe Support representatives through their Chat Support service without success. They have advised various solutions to the problem and two occasions I have given permission for the support representative to take remote control of my iMac in order to resolve the problem.
I’m trying to install Adobe Creative Suite 4 on my iMac 27-inch 2007 4.2Ghz i7 40GB RAM running macOS Sierra version 10.12.6
All applications with the exception of Acrobat 9 Pro have installed and run normally.
The first application that I opened was Photoshop, which functioned correctly.
When I opened Acrobat 9 Pro, within a few seconds I was presented with the Software Setup window requesting the serial number but when typing in the correct serial number, it advised me that it was not valid.
I have tried installing Adobe Creative Suite 4 from my DVDs supplied by Adobe and have also tried installing Adobe Creative Suite 4 from the latest version available on line from the Adobe web site from a link supplied by the Adobe Support Representative.
After several months, the support staff have given up and referred me to the “Forums” with the promise that a solution to the problem would be forthcoming.
Case numbers xxxxxxxxxx and xxxxxxxxx refer.
[Case numbers removed by moderator. This is a public user forum.]
The following support staff were involved in attempting to solve the problem on the following dates
10/04/2017 Nepuni
10/04/2017 Bharati
10/04/2017 Kunal
11/04/2017 Laishram
11/04/2017 Saurabh
05/08/2017 Ramiz Raja
05/08/2017 Rahul
07/08/2017 Shailash Kumar
07/08/2017 Abhishek
07/08/2017 Vinita
07/08/2017 Swati
19/10/2017 Kapil
19/10/2017 Parija
Is there anybody who can resolve this problem for me?
I'm surprised any of these people attempted to help you at all. Acrobat 9 is a very old version, not supported by Adobe and not compatible with your OS. If you want a working version get the current one.
The application does run on this OS, but the serial number is not accepted? Why will it not accept the serial number?
Read this thread:
Perhaps the serial number code doesn't run in this very mismatched system. If you upgrade Mac OS or your Mac it is vital to budget for all new apps. Your expectations don't match common experience.
I don't understand what is meant by "doesn't run". Why does Adobe not recognise the serial number?
Nobody says it doesn't run at all. We said it "not supported" and "not compatible". That might mean nothing works, it might mean bits of it fail. Do you not believe us? I don't think we can do anything except tell you the same thing in different words. If you still think it should work, consider, who told you that?
I have the same problem , re same Mac and issue. What is the correct ACROBAT program please to fix this problem
The correct version of Acrobat for you to use is Acrobat DC.
What version of MacOS does your Mac run? This is more important than the model of Mac.
