all right so I don't know if I'm just... missing something, or searching poorly, or what, but whenever I move a selection and then undo it, it seems there's a chance of the place I moved the selection to keeping the selection, along with the first part. if they overlap, it gets distorted. Also if I try to undo further, instead of it undoing stroke by stroke, large parts of my drawing disappear. There used to be a leg on the left.
and if I erase seemingly arbitrary parts of that mess... more or less everything disappears. For some reason.
Not to mention sometimes in such a state the eraser just... acts like the paintbrush tool.
It's incredibly annoying and I would love to know how to make this program not do this, so if anyone has any idea as to just... why... it'd be greatly appreciated.
Thanks for sharing the videos! The issue is reproducible using the steps you describe.
I've logged an internal bug to track this and will update here once this gets fixed.
reset your preferences -
http://helpx.adobe.com/flash/kb/re-create-preferences-flash-professional.html
(or remove Win: C:\Users\<username>\AppData\Local\Adobe\Animate CC 2017\ and
C\Users\<username>\AppData\Roaming\Adobe\Animate\2017\
Mac: /Users/<username>/Library/Application Support/Adobe/Animate CC 2017/ and
/Users/<username>/Library/Preferences/Adobe/Animate/2017/)
Okay this seems like an entirely different problem but I don't think I have an appdata folder in that spot? there is one in C:\Users\Default.migrated but there's no adobe data there.
I did delete the registry bit that the guide suggested though. It didn't help.
that would indicate a computer that has no adobe programs installed (nor have many non-adobe programs) or user error.
Ah, seems it's a hidden folder. I figured out how to access it and deleted the suggested files. However, the issue persists.
Can you please a test file and a video recording of how to reproduce the issue? It'll help us investigate and resolve this quickly.
You can use any file sharing program like dropbox and post the link.
I repeated the steps shown in the video on my Mac, and the same thing happens. So, it's not a Windows or video driver related problem.
It doesn't happen in CS6 in any mode, and it doesn't happen in Animate 2018 when doing object drawing mode.
I have found another perplexing issue with this. Dropbox - 2017-10-23_16-59-36.mp4
Your dropbox link was a bit messed up. I fixed it though, and this may work:
It's perhaps not right to count areas that disappear, that shouldn't have been there in the first place. Your first report leave shapes on the stage that can be selected, but you may have noticed that you can't Undo to get rid of that last shape. It's not really there, and I think the dots you drew that removed some parts was actually fixing the stage a bit.
Yeah i think that's part of it, and it wouldn't be as much of an issue if removing it were that easy.
Sometimes though, when the "not-real" parts disappear they take the "real" parts with them.
(also thank you for telling me of the broken link.)
I fixed the link in your other post.
Hopefully your first post will get fixed, and subsequent variations will not be needed to be fixed.
By the way, although Adobe Staff are already looking at this topic, you could report the bug and give your example video, here:
