Hi.
I recently bought a new computer on work, and installed adobe CC on it.
The problem I have: composition preview in after effects doesn't work. The whole area is either white, or grey. I can still do everything, make new layers, place a text, but I cant actually see what I'm doing.. I hope the picture below will give you a better idea of what this problem looks like.
I've tried reinstall program, but that did not help either. I've also tried to downgrade to older version of after effect. At first, it work, but after closing program, and open program again, same problem. Also tried to totally remove CC, and reinstal everything again. It seemed to have worked, untill I restarted my laptop.
Also tried clear caches, reset preferences, update gpu driver, even uninstall Sonic Suite, and all other fixes I found online, but that did not help either.
So far, the only fix that I've come across with, is removing After Effects, delete all user preferences and instaling older version, and just don't close it until I finish what I had to do.Now I don't really see this as a fix, more of a temporary solution because I do need projects to finish in the meantime and I don't really look forward to delete and reinstal after effects several times a day..
I'd really appreciate any advice Thanks!
Enter into File > Project Settings and check if you are using Mercury Hardware acceleration. Try to choose Mercury Software. And check if you are using the latest driver for your graphics card manufacturer.
Make sure if you are using the mercury playback engine with a video card that it is one recommended by Adobe:
After Effects System Requirements
You may also need to install the latest drivers for your NVDIA GPU:
Hi eeeeeed,
Sorry for this issue. Did you ever find a solution? Please let us know if you have or if you still need help.
Kevin
Hello,
I'm having the same issue, the whole preview area is just grey. Tried to uninstall and reinstall, or install previous AE versions but still the same. Help please Kevin-Monahan​
Hi, I think I solved the problem, open the program the default gpu or cpu as shown. The gpu maybe only coded for rendering... Kevin-Monahan​ if you could please send word to your coworkers forum/manager's email and a tech department to maybe fix this bug, it may allow for accelerated use and improved performance in the future.
It worked, thanks you!
Having the same problem with the latest upgrade
This also solved the issue for me as well!
HP ENVY Laptop 17-ae1xx
Display Info:
Name NVIDIA GeForce MX150
Adapter Type GeForce MX150, NVIDIA compatible
Adapter Description NVIDIA GeForce MX150
Driver Version 23.21.13.8873
Name Intel(R) UHD Graphics 620
Adapter Type Intel(R) UHD Graphics Family, Intel Corporation compatible
Adapter Description Intel(R) UHD Graphics 620
Driver Version 22.20.16.4691
Thanks sooo much!
