I can not start Photoshop or Bridge or LightRoom if my PC is runing e.g. 1 day or more. After restart is all OK. It only show splash screen... It end when HTML Language layer intitalize.
Restart Creative Cloud process doesn't help. After hybernate is problem too.
Win 7, 64bit. The latest versions. Prev versions has the same error.
Thanks a lot
Hi pavels,
If you were facing the same issue with the older versions of Photoshop as well then, Its a issue with your machine and you need to update the system hardware.
Have you tried rebuilding the operating system on your machine?
Mohit
I have new dell notebook (8moths old). All time i have this problem (and I would like to find solution) and the same HW, OS... (all patches I installed.
Hi pavels,
Whenever you face the same problem again, please open the task manager and look for the processes running related to Photoshop, Lightroom or Bridge. If you see anything running related to these application, please end task and try to open the application.
Also, you may right click on the application shortcut and click on "Run As administrator"
Let us know if that helps.
Mohit
Run as admin is the same.
Process Explorer:
And for Photoshop:
Killing subproceses doesnt help.
Old version (2017) start and freeze on page with recent files (the file list was empty). New version show only splash screen.
Clear temp (win\temp and user\appdata\local\temp) doesn't help.
