[Moderator branched to a new discussion and moved from Adobe Creative Cloud to Photoshop General Discussion.]
In a Production workflow, with images with multiple layers the "Re-Apply last Filter" is Command-F.
NOW ? Command-F brings up this stupid "search" feature.
I can't figure out how to reassign keyboard shortcuts (or want to), and can't figure how to get rid of "Search"?
Any help ??
You could use the new shortcut(s) Control-Command-F for "Re-Apply last Filter" and Shift-Conrol-Command-F for "Re-Apply last Filter with dialog"
or go to Edit>Keyboard Shortcuts>Application Menus>Filter and set Last Filter to Command-F
Just click on the existing shortcut to highlight the field, type in Command-F then press Accept.
See here for an explanation as to why adobe change it:
I've branched this to a new discussion and moved it to the Photoshop forum for you.
Thank you so much!!
I have been using PS for years and this new update is TERRIBLE. It takes well over a minute to load on my homebuilt pc which has 32Gb of ram, a core i7 cpu and a pretty solid video card. I went through the entire list of "performance tips" and it did not change a thing. DO THEY TEST THIS STUFF?
That one was a head scratcher. Changing it made no sense as I'm not going to be trying to find stuff as I work.
