Hi
I developed a CC12 plug-in that sends soap request to a Web Service. To do that I'm using libcurl (curl ) and it works, but to make it work on Mac I have to replace the OS libcul lib with mine, because even if the liburl has been compiled in static_mt the the plug-in try to resolve it with the OS one. I've tried a different solution like https://pocoproject.org/index.html but it conflicts with SDK headers (you can resolve it modifing WShukHeaders.h in this way C++ Redefinition Header Files (winsock2.h) - Stack Overflow but it really sucks as solution ).
Does anyone know a good solution to make http requests in the plug-in?
Many thanks in advance.
Massimo
Hi Massimo,
I'm using curl too and simply integrated the source code after configuration into my project. This avoids your problem and compile time isn't much affected. Maybe you want to choose this option too?
Best, Peter
Hi Massimo,
Best, Peter
Hi Peter,
Can you share with me some tips about how do that? I've tried to add the VS projects present in curl package 'libcurl' and 'curlsrc' to my solution but the linker still serch for an external link whilke compiling my plug-in. I also tried to add the source files from the 'libcurl' project to my project but I get this error :
Error 1 error C1853: 'C:\Users\paon.m\Desktop\SourceTree\IndesignPlugIn\_built\Indesign_CC_version_2015\\objdx64\PageBuilderConnector\PageBuilderConnector.pch' precompiled header file is from a previous version of the compiler, or the precompiled header is C++ and you are using it from C (or vice versa) C:\Users\paon.m\Desktop\SourceTree\IndesignPlugIn\libs\curl-7.37.0\lib\amigaos.c 1 1 PageBuilderConnector
Hi Massimo,
You should use static library.
Check this link:
http://www.codepool.biz/build-use-libcurl-vs2015-windows.html
// Karoly
Hi Karoly
The problem is on Mac, to make the plug-in works I have to copy:
licurl.a
libcurl.la
libcurl.4.dylib
libcrul.dylib
in /usr/locol/lib, otherwise Indesign crash. I'm looking for a way to avoid to copy those files
Including libcurl in C project - Stack Overflow
"3down voteaccepted | Mac OS X comes with a copy of libcurl, so your application doesn't need its own copy. You didn't mention the version of Xcode you're using. The following applies to 3.2, but may not work in 4. To use the version of libcurl provided by the system, go to |
I use libcurl.4.dylib
It works for me.
// Karoly
Hi
I'm using Xcode 5.0.2 for CC10 and CC11 on MacOs 10.9, Xcode 7.2.1 for CC12 on MacOs 10.11 as per SDK documentation.
the problem is I'm using a different version of libcurl that is not the same of the Max OS X one. So if at runtime it links to the libcurl in /usr/lib Indesign crash, putting those libraries in /usr/local/lib resolve the issue because they are taken at runtime instead of the ones in /usr/lib
Maybe you need to create separated projects for all CC variation.
eg. CC 2014, CC 2015, CC 2017 and CC 2018
// Karoly
I have different projects for CC variations.
I have tried your solution but Indesign still crashing:
Responsible: | Adobe InDesign CC 2017 [58092] |
User ID: | 503 |
Date/Time: | 2017-11-03 11:22:23.709 +0100 |
OS Version: | Mac OS X 10.11.5 (15F34) |
Report Version: | 11 |
Anonymous UUID: | 1446CAF6-C984-7C03-3F7E-DC4E110D673F |
Time Awake Since Boot: 85000 seconds
System Integrity Protection: enabled
Crashed Thread: | 0 Dispatch queue: com.apple.main-thread |
Exception Type: | EXC_BAD_ACCESS (SIGSEGV) |
Exception Codes: | KERN_INVALID_ADDRESS at 0x0000000000000000 |
Exception Note: | EXC_CORPSE_NOTIFY |
VM Regions Near 0:
__TEXT | 0000000100775000-000000010077f000 [ 40K] r-x/rwx SM=COW /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Adobe InDesign CC 2017 |
Global Trace Buffer (reverse chronological seconds):
1.483033 | CFNetwork | 0x00007fff96e043cb TCP Conn 0x7fe92a5441d0 SSL Handshake DONE | |
1.484354 | CFNetwork | 0x00007fff96e043cb TCP Conn 0x7fe92a542bd0 SSL Handshake DONE | |
1.831018 | CFNetwork | 0x00007fff96e042a7 TCP Conn 0x7fe92a5441d0 starting SSL negotiation | |
1.831143 | CFNetwork | 0x00007fff96e02c71 TCP Conn 0x7fe92a5441d0 complete. fd: 61, err: 0 | |
1.831143 | CFNetwork | 0x00007fff96e9154b TCP Conn 0x7fe92a5441d0 event 1. err: 0 | |
1.831923 | CFNetwork | 0x00007fff96e042a7 TCP Conn 0x7fe92a542bd0 starting SSL negotiation | |
1.832159 | CFNetwork | 0x00007fff96e02c71 TCP Conn 0x7fe92a542bd0 complete. fd: 59, err: 0 | |
1.832361 | CFNetwork | 0x00007fff96e9154b TCP Conn 0x7fe92a542bd0 event 1. err: 0 | |
2.006383 | CFNetwork | 0x00007fff96e01f43 TCP Conn 0x7fe92a5441d0 started | |
2.007608 | CFNetwork | 0x00007fff96e01f43 TCP Conn 0x7fe92a542bd0 started | |
2.236606 | CFNetwork | 0x00007fff96e043cb TCP Conn 0x7fe934a552b0 SSL Handshake DONE | |
2.237275 | CFNetwork | 0x00007fff96e043cb TCP Conn 0x7fe92a5441d0 SSL Handshake DONE | |
2.786144 | CFNetwork | 0x00007fff96e042a7 TCP Conn 0x7fe934a552b0 starting SSL negotiation | |
2.786357 | CFNetwork | 0x00007fff96e02c71 TCP Conn 0x7fe934a552b0 complete. fd: 61, err: 0 | |
2.786598 | CFNetwork | 0x00007fff96e9154b TCP Conn 0x7fe934a552b0 event 1. err: 0 | |
2.791605 | CFNetwork | 0x00007fff96e042a7 TCP Conn 0x7fe92a5441d0 starting SSL negotiation | |
2.791764 | CFNetwork | 0x00007fff96e02c71 TCP Conn 0x7fe92a5441d0 complete. fd: 59, err: 0 | |
2.791809 | CFNetwork | 0x00007fff96e9154b TCP Conn 0x7fe92a5441d0 event 1. err: 0 | |
2.961898 | CFNetwork | 0x00007fff96e01f43 TCP Conn 0x7fe934a552b0 started | |
2.967702 | CFNetwork | 0x00007fff96e01f43 TCP Conn 0x7fe92a5441d0 started | |
9.368071 | CFNetwork | 0x00007fff96e043cb TCP Conn 0x7fe933452b80 SSL Handshake DONE | |
9.414229 | CFNetwork | 0x00007fff96e042a7 TCP Conn 0x7fe933452b80 starting SSL negotiation | |
9.414442 | CFNetwork | 0x00007fff96e02c71 TCP Conn 0x7fe933452b80 complete. fd: 54, err: 0 | |
9.414496 | CFNetwork | 0x00007fff96e9154b TCP Conn 0x7fe933452b80 event 1. err: 0 | |
9.462354 | CFNetwork | 0x00007fff96e01f43 TCP Conn 0x7fe933452b80 started | |
13.257348 | CFNetwork | 0x00007fff96e043cb TCP Conn 0x7fe92d8ab130 SSL Handshake DONE | |
13.359143 | CFNetwork | 0x00007fff96e042a7 TCP Conn 0x7fe92d8ab130 starting SSL negotiation | |
13.359343 | CFNetwork | 0x00007fff96e02c71 TCP Conn 0x7fe92d8ab130 complete. fd: 25, err: 0 | |
13.359353 | CFNetwork | 0x00007fff96e9154b TCP Conn 0x7fe92d8ab130 event 1. err: 0 | |
13.404259 | CFNetwork | 0x00007fff96e01f43 TCP Conn 0x7fe92d8ab130 started |
Did you use libcurl.4.dylib for your CC 2017 project?
If "yes" in this case I can only guess:
1. you use a wrong system libraries
Check: remove all libcurl references from project -> compile - > test
If test is OK goto point 2.
2. your libcurl.4.dylib is wrong for your selected and precompiled Adobe libraries
Check your system libraries settings in your project for different xcode versions
If I have to guess point 2. your real problem:
- installed systemlibraries are mixed in your project (eg. lib path point to a fail system library version)
or
- wrong systemlibrary settings (eg. your OSX 10.11 systemlibraries contain fail libraries)
// Karoly
I implemented the Peter's solution and it works! It was quite hard compile lib curl with Xcode , if someone needs help about that I could help
@paon.m do you have any sample or github location which I can refer to? I am trying to interact http api's in plugin. Thanks
