10 Replies Latest reply on Oct 25, 2017 12:03 PM by SuperMerlin
    [CS6] Custom Panel hook for C++ API question
    i73 Level 1
      I have a plugin (.dll) written in C++ that I want to create a custom panel for, so a few questions:
      Is this possible?
      If so, could you point me in the direction of what I have to use, I understand that I can use ActiveXObject for web to call native dlls in Js. Would this work for Photoshop?
        • 1. Re: [CS6] Custom Panel hook for C++ API question
          Jarda Bereza Level 4
          Your .dll (with different name in extension) should have JSX interface. So you can use classic Action Manager code for you own plugin.
          • 2. Re: [CS6] Custom Panel hook for C++ API question
            SuperMerlin Level 5
            There is an example of a dll in the Bridge SDK Bridge Developer Center
            It also shows how to interface with JSX.
            • 3. Re: [CS6] Custom Panel hook for C++ API question
              i73 Level 1
              Does the classic Action Manager use the Bridge?
              Thanks guys, after talking to the artists they entirely want to stay away from the Bridge at all costs. Half of them already uninstalled it from their machines. Do you have any other suggestions?
              • 4. Re: [CS6] Custom Panel hook for C++ API question
                SuperMerlin Level 5
                Although the example is in the Bridge SDK the dll can be used in Photoshop see "BasicExternalObject" example.
                In fact I use that example with modifications for use in Photoshop.
                • 5. Re: [CS6] Custom Panel hook for C++ API question
                  i73 Level 1
                  Thank you Merlin, quick question about the 'BasicExternalObject' will this contain UI examples or just the connection to the API calls through Js?
                  • 6. Re: [CS6] Custom Panel hook for C++ API question
                    You can create GUI in C++ or in JSX
                    Anyway in C++ it would be better.
                    • 7. Re: [CS6] Custom Panel hook for C++ API question
                      i73 Level 1
                      I've currently created the GUI from a C++ resource file but the only way to access it is through File->Automation->MyPlugin, I need a better way to do this with a custom panel icon or something else.
                      • 8. Re: [CS6] Custom Panel hook for C++ API question
                        SuperMerlin Level 5
                        Yes it has some example calls, also see Action Manager (Script Listener) code converter script! for a modified cpp that gives access to the system command and clipboard functions.
                        • 9. Re: [CS6] Custom Panel hook for C++ API question
                          i73 Level 1
                          Hey Super, sorry to be a nuisance I'm currently looking at the code from the source you supplied 'AM Code Replacement.jsx' and it seems it's just opening the written file and parsing out the text, I don't see where exactly it's calling any API functions (Js is not my language so please tell me if I'm missing something):
                          // https://forums.adobe.com/thread/2249343 / CS5.1 / Kukurykus / 15.12.16
                          // it changes ActionManager code to be much more readeable and neat
                          function rw(v1, v2, v3) {v2.open(v1), v1 < 'w' ? v3 = v2.read() : v2.write(v3), v2.close(); return v3}
                          (win = new Window('palette' )).add('statictext {text: "Please wait to end of this process..."}'), win.show()
                          c = rw('r', File('~/Desktop/ScriptingListenerJS.log')).replace(/(.*\n(.*\n)+|^)([\/ =]+\n)+(.*(\n.*)+)\n\n/, '$4')
                          r = {a: ["'(^|;\\n) *(var )?'", '\r'], b: ["'\\\\( '", '('], c: ["' \\)'", ')'], d: ["'\"'", '\''], e: ["'ref'", 'REF'],
                          f: ["'desc'", 'DSC'], g: ["'list'", 'LST'], h: ["'string'", 's'], i: ["'char'", 'c'], j: ["'IDToTypeID'", 'TT']}
                          eval(l ="for(i in r) c = c.replace(eval('RegExp(' + r[i][0] + ',\"g\")'), r[i][1])");
                          for(i = 0, ARR = eval(arr = '[r.e[1], r.f[1], r.g[1]]'); i < (ARR).length; i++) {
                          if (!i) arr = eval(arr.replace(/1/g, '0')); arr[i] = ARR[i].toLowerCase(), n = 1
                          while(num = c.match(RegExp(ARR[i] + '\\d+'))) c = c.replace(RegExp(num, 'g'), eval(tLC = "arr[i]") + n), n++
                          if (num && !RegExp((onl = eval(tLC)) + 2).test(c)) c = c.replace(RegExp(onl + 1, 'g'), onl)
                          while(lne = c.match(/(\w+) = ((s|c)TT\('#?[\w ]*'\))/)) {
                          if ((Ps = /P.*p/.test(app.name)) && lne[3] == 'c') {
                          l2 = lne[2], lne[2] = "sTT('" + eval(lne[2].replace(/cTT(.*)/, 'typeIDToStringID(charIDToTypeID$1)')) + "')"
                          if (/''/.test(lne[2])) lne[2] = l2
                          eval((slh = "c = c.replace(RegExp(lne[0].replace(/(?=\\()/, '\\\\').replace(/(?=\\))/, '\\\\')), '')")
                          + ".replace(RegExp(lne[1] + '(?=,|\\\\))' + '\\\\b'), lne[2])")
                          for(i = 0; i <  arr.length; i++) {
                          while(lne = c.match(RegExp('(\\b' + arr[i] +'(\\d*))' + '.*?\)')))  {
                          eval(slh + ".replace(RegExp('\\\\b' + lne[1] + '(?!\\\\d)'), '(' + lne[0] + ')')\
                          .replace(RegExp('\\\\b' + lne[1] + '(?!\\\\d)', 'g'), ARR[i] + lne[2])")
                          for(i = 0; i < ARR.length; i++) {
                          c = c.replace(RegExp(' \\((' + String(ARR).replace(/,/g, "|") + ')\\D[= ]+(.*?(\)))\\3', 'g'), ' $2')
                          .replace(RegExp(ARR[i], 'g'), arr[i])
                          r = {a: ["'((\\\\.0+\\\\b|(\\\\.[0-9]{0,5}?)0+))(?=\\\\))'", '$3'], b: ["'(\\\\d)undefined'", '$1'],
                          c: ["'\\\\r\\\\s+'", '\n'], d: ["'\\)(\\n|\\r)\\\\('", ');\n('], e: ["'\\r|\\n'", '\n\t']}
                          c = 'function cTT(v) {return charIDToTypeID(v)}; function sTT(v) {return stringIDToTypeID(v)}\
                          \nfunction someName() {' + eval(l) + '\n}\nsomeName()', rw('w', File('~/Desktop/Code.txt'), c)
                          s = [$.screens[0].right - 880, (l = c.match(/\n/g).length + 1) < 69 ? l * (16.14 - (l - 5) * (.091 / 67)) : $.screens[0].bottom - 100]
                          ans = (win = new Window('dialog' )).add('edittext {preferredSize:'+ uneval(s)+', properties: {multiline: true}}')
                          ans.text = c, ans.active = true, win.add ("button", [0,0,28,19], "OK", {name:'close'}); if (!/P.*p/.test(app.name)) win.show()
                          // if (Ps) File(File($.fileName).path + '/AM.exe').execute();  win.show() // deprecated since for Windows only
                          if (/P.*p/.test(app.name)) app.system((/Windows/.test($.os) ? 'clip' : 'pbcopy') + ' < %HOMEPATH%/desktop/Code.txt')
                          • 10. Re: [CS6] Custom Panel hook for C++ API question
                            SuperMerlin Level 5
                            As an example, compile the code (64bit) place the dll  in the presets/scripts folder.
                            Then you can run this script in ExtendScript Toolkit
                            #target Photoshop
                            var SCRIPTS_FOLDER =  decodeURI(app.path + '/' + localize('$$$/ScriptingSupport/InstalledScripts=Presets/Scripts'));
                            var libPath =SCRIPTS_FOLDER + "/BasicExternalObject.dll";
                            var  psEX = new ExternalObject("lib:" + libPath);
                            $.writeln(psEX.getClipboard());
                            $.writeln("-----------------------------");
                            //Put data on clipboard
                            psEX.setClipboard("This is put on the clipboard!");
                            //Get data from clipboard
                            //Clear clipboard
                            psEX.clearClipboard();
                            var task = psEX.systemCmd('tasklist').match(/Photoshop.exe/im);
                            if(task == null){
                            $.writeln("Photoshop is not running");
                            }else{
                                $.writeln("Photoshop is running");
                            This is the basics of calling and retrieving data.
                            By the way there is a compiled dll here. http://wikisend.com/download/563538
                            Wikisend: free file sharing service
