Hi - as mentioned above in the layers panel when I select a layer and try and move it with the move tool PS jumps to the bottom layer and that moves instead. I have to manually select the object / layer to move. Any solutions? (this with 2018, I installed 2017 as well, same issue)
When the Move tool is selected, do you see Auto-Select turned on in the Options bar? If so, remove the checkmark.
That's it!!!! thank you so much (am on a big deadline )
Thank you for the answer! I have been struggling with this for days.
In photoshop there is very little that is intuitive in my experience
