In any document > when in full-screen mode > zooming in/out > the image/artboard snaps to a new position.
Mac OS, Wacom Tablet, Asus External Monitor.
Problem does not arise when in full screen (pressing F twice, not sure what it's called)
Additional posts with similar issues:
Has anyone found a solution for this?
Hello, if you had the issue also on Ps 2020,
Ps22 that has just been released does have a zoom centering issue in its fixed list https://helpx.adobe.com/photoshop/kb/fixed-issues.html#photoshop-desktop-fixed-issues
I recommend to install it while keeping the older version installed, as explained in: https://helpx.adobe.com/be_en/download-install/using/install-previous-version.html
Hi JustinCowts,
This is a known issue and we are working on it.
Please refer to the posts you've mentioned for updates on this issue.
Akash
Hi Akash Sharma,
When will this be solved? We pay a lot of money for this software. It needs to work flawlessly.
Hi zoomdogmedia,
Sorry for the inconvenience caused. Our Engineers are aware of it and are working to resolve this issue.
Akash
So just installed the latest update. Tested this immediately. Still not fixed. When are you going to patch this?
Yeah Adobe, please fix this!! It's super annoying.
This is also occurring when creating a new blank layer, new layer merged and when flattening a file. Only in Full Screen Mode with Menu Bar. (iMac 5k, High Sierra) Grrr...
You can try to checklist application frame.
go to menu window - application frame
Center snap will be off.
Hope it helps for you.
Under Window>Application Frame>I only have the option to tick 'Options' or 'Tools' there is no 'Centre snap' displayed
This is causing a lot of issues in my workflow and I haven't found a workaround. Can I be notified when this is resolved so I can update as soon as possible?
When is this going to be fixed? Definitely a glitch as the full-screen mode works fine.
Well, the update didn't fix the problem...
I second that.
Didn't fix it for me either 😞
Ditto here this drives me nuts
in preferences under the tools tab click "zoom resizes window"
