When I make an animation with the camera tool being used, when I publish or export to a swf video it only shows the bottom right corner of the animation but shows all of the background colour, not just a corner. This only started happening after the I installed the latest update. I use a surface pro 4 to animate on.
This one:
I have seen similar issues if you are using the Clip content outside of stage option (the button next to the stage scale text field). Does it make a difference if that button isn't selected?
Where is the button? I cant find anything that says clip content
Its located at the top right corner of the document. The attached image might help.
We are working on a proper fix to this issue. In the meantime, please use this workaround.
This one:
no that didn't work it still only showed the bottom right corner of the screen
Can you please share the fla file ?
sorry this is my first forum, how do I attach a file?
There isn't a way to do that. You would use Google Drive, or DropBox, or some other file sharing service, then past the link here.
I'm trying uninstalling then reinstalling the program and if that doesn't work I'll try to get the older version of it, may this work?
The problem doesn't happen in my tests, which could mean that your FLA has problems. If you start a new file and reconstruct what you had made, do you still get the same problem?
yes I tried that but the problem still happened when I published it
Can you post a swf online somewhere, and the FLA that made it? I want to see if it's a playback issue, it could be that the swf is ok for other people who play it.
