Lightroom/Photoshop Edits not showing up in Photoshop
Jul 16, 2017 Jul 16, 2017
I just recently purchased and downloaded Lightroom CC (Version Adobe Lightroom [1117303]) and Photoshop CC (Version 2017.1.1) on a Mac, OS 10.12.5. I've been using Lightroom for a couple of years and I had an older version of Photoshop for a while. I want to be able to edit a photo from a collection in Photoshop and have it returned to the collection.
If I use "Edit In" for photoshop, the file transfers to PS okay and I can edit it fine, but if I save and close it, it doesn't show up in LightRoom any more. Sometimes I get a empty photo box, with a exclamation point that expands to a complaint that the file could not be found. But that's not consistent.
In Lightroom 5 if I edited a photo in PS it returned okay. I also have a number of other editors imported to PS, like Tonality CK to eures, dit the photo. That used to work as well, but with the latest version of LR, it doesn't work at all. And once I use it, the selection is greyed out for all other photos in the collection.
Is anyone else seeing anything like this?
Can anyone suggest an answer. I thought going to the newest version would give me more features, not less.
-Peter
7.1K
Community Expert , Jul 23, 2017 Jul 23, 2017
Bob, a comment on
there is only PSD and Tiff
It is possible to add Photoshop as an "Additional External Editor" and select JPG as an option.
Lightroom does force a question "Use anyway" when you create the preset in Preferences.
ps:  On my laptop I updated 'all'  Lr Ps ACR, two days ago, and the problem with the file not appearing back in Lr seems to have been fixed- for me.
Yes I am seeing similar, but in my case nothing comes back to Lightroom! I have to synchronize the folder where the original is located to 'import' the new Ps edited file.
And my Photoshop defined Workspace has changed back to Adobe's default without my doing!
One thought (as you do see an empty box)- check the Photoshop preferences-
Edit > Preferences > File Handling / Maximize psd and psb FIle Compatability  = ALWAYS.
I have the same or at least similar issue. After taking the latest LR update.
Open a file from LR to edit in Photoshop CC 2017
Make my edits - then save as jpeg
Go back to LR in Grid View for example - no jpeg to be seen or found - even via a LR search
Look in Finder and the jpeg is has been saved to the folder so it is there
Try to manually sync the folder via LR - nothing
Now I see the original file in Grid View at the top says NEF+JPEG
Do not have stacking enabled in Preferences
Do have checked treat JPEG next to RAW as separate (didn't have that checked before the update)
Again this just changed after taking on the latest update via the cloud.
Fairly new to LR and don't know where to go from here. I need to be able to view my edits/jpegs again in LR.
Any thoughts or help greatly appreciated.
Under the external editing preferences for Photoshop there is only PSD and Tiff so you must be doing a SAVE AS instead of SAVE in Photoshop to get a JPG so the photo will not be automatically reimported into Lr.
I do notice a NEW glitch using EDIT IN.  When doing an Edit In from Develop mode the returned photo in the filmstrip is highlighted but is only a GRAY BOX even though the full photo is correct.  As soon as you select another photo the thumbnail regenerates.  The behavior is correct when doing the Edit In from Library.
Bob, a comment on
wobertc
Thanks for the info.  I didn't think about the "Additional External Editor" beings the OP was using Photoshop and Lightroom CC versions.
My glitch about the gray thumbnail showed up when I installed CC2015.12, at least I think so as I don't ever remember seeing the problem.
Oct 25, 2017 Oct 25, 2017
I have seen something similar since upgrading to Lightroom Classic CC and Photos CC 2018.  Ino Lightroom I choose Photo, Edit in Adobe Photoshop CC 2018. Note, I have the image in a Collection, and I have the image selected in the Collection (not the “Folder”). I do my edits in Photoshop and use the Luminar plugin. I save my image, then I return to Lightroom.  All I see is the original NEF file (Nikon raw format). It turns out the image did get saved, but I have to return to the Folder to see it. The edited image is not part of the Collection. Before I upgraded the edited image would be in the Collection. I cannot figure out where the setting resides that will make my image show up in the Collection. Help!
Joe
Oct 26, 2017 Oct 26, 2017
I have upgraded to Lr-Classic (windows-10)
Editing in an External editor (Nik) successfully returns the new file to my Collection next to the original.
It works for me from both a Standard Collection and a Smart Collection, even from the Develop module when editing a file in a Collection.
In fact  from Grid View I see the new file created in the collection for a brief moment before Nik plugins open with the 'new' file'.
So I am at a loss to explain why you do not see the same, and to my knowledge there is no "Setting" to turn on/off.
Perhaps Luminar is changing something? Can you try other external editor actions?
Oct 27, 2017 Oct 27, 2017
The issue was happening with and without using the Luminar filters in Photoshop.
I had to reboot my iMac for another software install. Afterwards, the issue went away. Now after I save in Photoshop, I reopen Lightroom (in same Collection) and the PDF version shows up. Not sure how that resolved the issue, but I am happy!
on a side note, I am seeing a significant improvement in processing times with Lightroom.
thanks, joe
