2
What's New in Illustrator Scripting CC2018
Oct 21, 2017 Oct 21, 2017
CC2018
New Class
Asset
Adobe Illustrator 22 Type Library
An (exportable) asset.
Properties
Asset.assetID  (Read Only)
Data Type: Int32
The UID for the asset which is unique within a document.
Asset.assetName
Data Type: string
Name of the asset.
Asset.parent  (Read Only)
Data Type: Object
The object's container.
Asset.typename  (Read Only)
Data Type: string
The class name of the object.
Methods
Asset.getNormalizedName (): string
Gets the normalized name without special characters, such that it can be used as a file name.
Asset.remove ()
Deletes this object.
Asset.removeAll ()
Deletes all elements.
New Collection
Assets
A collection of assets.
Properties
Assets.length  (Read Only)
Data Type: int
Number of elements in the collection.
Assets.parent  (Read Only)
Data Type: Object
Assets.typename  (Read Only)
Data Type: string
Methods
Assets.add (sourceArt:any): Asset
Creates an asset from the given art(s)
sourceArt: Data Type: any
The page item(s) to apply to.
Assets.addFromSelection (): Asset
Creates an asset from the selected arts.
Assets.getByID (assetID: Int32 😞 Asset
Gets the asset with the specified AssetID.
assetID: Data Type: Int32
The UID of the asset.
Assets.getByName (name: string 😞 Asset
Get the first element in the collection with the provided name.
name: Data Type: string
Assets.remove (assetID: Int32 )
Deletes the asset with specified id.
UID of the asset to be deleted.
Assets.removeAll ()
Application Class
New Method
Application.getIsFileOpen (filePath: string 😞 Boolean
Returns if the specified filePath is open.
filePath: Data Type: string
The filePath to be checked.
Document Class
New Method
Document.exportForScreens (exportFolder: File , exportFormat: ExportForScreensType , options:any, itemToExport: ExportForScreensItemToExport , fileNamePrefix: string )
Export the specified document/asset(s)/artboard(s)
exportFolder: Data Type: File
The folder where the exported documents/assets/artboards are saved.
exportFormat: Data Type: ExportForScreensType
The file type in which the document is exported.
options (optional): Data Type: any
Options for the file type specified.
itemToExport (optional): Data Type: ExportForScreensItemToExport
What to export.
fileNamePrefix (optional): Data Type: string
String prepended to each file name.
DocumentPreset Class
New Properties
DocumentPreset.documentBleedOffset
Data Type: Rect
Document bleed offset rect.
DocumentPreset.documentBleedLink
Data Type: Boolean , Default Value: true
Document link for bleed values.
TextRange Class
New Properties
TextRange.start
Data Type: Int32
Start index of the text range.
TextRange.end
Data Type: Int32
End index of the text range.
New Methods
TextRange.getParagraphLength (): Int32
Get the length of the first paragraph.
TextRange.getTextRunLength (): Int32
Get the length of the first text run.
CharacterAttributes Class
New Properties
CharacterAttributes.kana
Data Type: Boolean
Does the Japanese OpenType support kana?
CharacterAttributes.ruby
Data Type: Boolean
Does the Japanese OpenType support ruby?
CharacterAttributes.kashidas
Data Type: KashidasType
Kashidas attribute.
CharacterAttributes.dirOverride
Data Type: DirOverrideType
Direction override attribute.
CharacterAttributes.digitSet
Data Type: DigitSetType
Digit set attribute.
CharacterAttributes.diacVPos
Data Type: DiacVPosType
Diacritics positioning attribute.
CharacterAttributes.diacXOffset
Data Type: number
Diacritics x offset attribute.
CharacterAttributes.diacYOffset
Data Type: number
Diacritics y offset attribute.
CharacterAttributes.justificationAlternates
Data Type: Boolean
Justification alternates attribute.
CharacterAttributes.overlapSwash
Data Type: Boolean
OpenType overlap swash attribute.
CharacterAttributes.stretchedAlternates
Data Type: Boolean
Stretched alternates attribute.
ParagraphAttributes Class
New Properties
ParagraphAttributes.composerEngine
Data Type: ComposerEngineType
Composer engine attribute.
ParagraphAttributes.defaultTabWidth
Data Type: number
Default tab width attribute.
ParagraphAttributes.kashidaWidth
Data Type: KashidaWidthType
The Kashida Width attribute.
ParagraphAttributes.paragraphDirection
Data Type: ParagraphDirectionType
Main writing direction attribute.
Here's the xml including all Enumerations, please note it might have missing closing tags.
<map title="Adobe Illustrator 22 Type Library" time="Thu Feb 2 12:20:30 UTC+5 2017">
      <topicref navtitle="JPEGCompressionMethodType" href="#/JPEGCompressionMethodType" />
      <topicref navtitle="KashidasType" href="#/KashidasType" />
      <topicref navtitle="DirOverrideType" href="#/DirOverrideType" />
      <topicref navtitle="DigitSetType" href="#/DigitSetType" />
      <topicref navtitle="DiacVPosType" href="#/DiacVPosType" />
      <topicref navtitle="KashidaWidthType" href="#/KashidaWidthType" />
      <topicref navtitle="ComposerEngineType" href="#/ComposerEngineType" />
      <topicref navtitle="ParagraphDirectionType" href="#/ParagraphDirectionType" />
      <topicref navtitle="ExportForScreensScaleType" href="#/ExportForScreensScaleType" />
      <topicref navtitle="ExportForScreensType" href="#/ExportForScreensType" />
      <topicref navtitle="ExportForScreensItemToExport" href="#/ExportForScreensItemToExport" />
      <topicref navtitle="ExportForScreensOptionsJPEG" href="#/ExportForScreensOptionsJPEG" />
      <topicref navtitle="ExportForScreensOptionsPNG8" href="#/ExportForScreensOptionsPNG8" />
      <topicref navtitle="ExportForScreensOptionsPNG24" href="#/ExportForScreensOptionsPNG24" />
      <topicref navtitle="ExportForScreensOptionsWebOptimizedSVG" href="#/ExportForScreensOptionsWebOptimizedSVG" />
      <topicref navtitle="ExportForScreensPDFOptions" href="#/ExportForScreensPDFOptions" />
    <topicref navtitle="Classes used for working with (exportable) assets in Adobe Illustrator">
      <topicref navtitle="Asset" href="#/Asset" />
    </topicref>
      <topicref navtitle="Assets" href="#/Assets" />
  </map>
  <package>
    <classdef name="ExportForScreensScaleType" enumeration="true">
      <shortdesc>Export for screens scale type.</shortdesc>
      <elements type="class">
        <property name="SCALEBYFACTOR" rwaccess="readonly">
          <shortdesc>Scale artwork by factors like 1x, 2x, 3x and so on, where 1x means 72 ppi.</shortdesc>
          <datatype>
            <type>int</type>
            <value>0</value>
          </datatype>
        </property>
        <property name="SCALEBYWIDTH" rwaccess="readonly">
          <shortdesc>Scale artwork by specifying artwork width in pixels like 100px, 124px etc. Height of the artwork is adjusted automatically to maintain the aspect ratio.</shortdesc>
          <datatype>
            <type>int</type>
            <value>1</value>
          </datatype>
        </property>
        <property name="SCALEBYHEIGHT" rwaccess="readonly">
          <shortdesc>Scale artwork by specifying artwork height in pixels like 100px, 124px etc. Width of the artwork is adjusted automatically to maintain the aspect ratio.</shortdesc>
          <datatype>
            <type>int</type>
            <value>2</value>
          </datatype>
        </property>
        <property name="SCALEBYRESOLUTION" rwaccess="readonly">
          <shortdesc>Scale artwork by specifying resolution in ppi like 72 ppi, 100 ppi, 144 ppi etc.</shortdesc>
          <datatype>
            <type>int</type>
            <value>3</value>
          </datatype>
        </property>
      </elements>
    </classdef>
    <classdef name="ExportForScreensType" enumeration="true">
      <shortdesc>Export for screens type.</shortdesc>
        <property name="SE_JPEG100" rwaccess="readonly">
          <shortdesc>Export file in JPEG (100% quality) format.</shortdesc>
          <datatype>
            <type>int</type>
            <value>1</value>
          </datatype>
        </property>
        <property name="SE_JPEG80" rwaccess="readonly">
          <shortdesc>Export file in JPEG (80% quality) format.</shortdesc>
          <datatype>
            <type>int</type>
            <value>2</value>
          </datatype>
        </property>
        <property name="SE_JPEG50" rwaccess="readonly">
          <shortdesc>Export file in JPEG (50% quality) format.</shortdesc>
          <datatype>
            <type>int</type>
            <value>3</value>
          </datatype>
        </property>
        <property name="SE_JPEG20" rwaccess="readonly">
          <shortdesc>Export file in JPEG (20% quality) format.</shortdesc>
          <datatype>
            <type>int</type>
            <value>4</value>
          </datatype>
        </property>
        <property name="SE_SVG" rwaccess="readonly">
          <shortdesc>Export file in SVG format.</shortdesc>
          <datatype>
            <type>int</type>
            <value>5</value>
          </datatype>
        </property>
        <property name="SE_PNG8" rwaccess="readonly">
          <shortdesc>Export file in PNG 8-bit format.</shortdesc>
          <datatype>
            <type>int</type>
            <value>6</value>
          </datatype>
        </property>
        <property name="SE_PNG24" rwaccess="readonly">
          <shortdesc>Export file in PNG 24-bit format.</shortdesc>
          <datatype>
            <type>int</type>
            <value>7</value>
          </datatype>
        </property>
        <property name="SE_PDF" rwaccess="readonly">
          <shortdesc>Export file in Acrobat PDF format.</shortdesc>
          <datatype>
            <type>int</type>
            <value>8</value>
          </datatype>
        </property>
      </elements>
    </classdef>
    <classdef name="KashidasType" enumeration="true">
      <shortdesc>The kashida type constants.</shortdesc>
        <property name="kashidaDefault" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>0</value>
          </datatype>
        </property>
        <property name="kashidaOn" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>0</value>
          </datatype>
        </property>
        <property name="kashidaOff" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>1</value>
          </datatype>
        </property>
      </elements>
    </classdef>
    <classdef name="DirOverrideType" enumeration="true">
      <shortdesc>Direction override type constants.</shortdesc>
        <property name="dirOverrideDefault" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>0</value>
          </datatype>
        </property>
        <property name="dirOverrideLTR" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>1</value>
          </datatype>
        </property>
        <property name="dirOverrideRTL" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>2</value>
          </datatype>
        </property>
      </elements>
    </classdef>
    <classdef name="DigitSetType" enumeration="true">
      <shortdesc>Digit set type constants.</shortdesc>
        <property name="defaultDigits" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>0</value>
          </datatype>
        </property>
        <property name="arabicDigits" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>1</value>
          </datatype>
        </property>
        <property name="hindiDigits" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>2</value>
          </datatype>
        </property>
        <property name="farsiDigits" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>3</value>
          </datatype>
        </property>
      </elements>
    </classdef>
    <classdef name="DiacVPosType" enumeration="true">
      <shortdesc>Diacritic vertical position type constants.</shortdesc>
        <property name="diacVPosOff" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>0</value>
          </datatype>
        </property>
        <property name="diacVPosLoose" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>1</value>
          </datatype>
        </property>
        <property name="diacVPosMedium" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>2</value>
          </datatype>
        </property>
        <property name="diacVPosTight" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>3</value>
          </datatype>
        </property>
        <property name="diacVPosOpenType" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>4</value>
          </datatype>
        </property>
      </elements>
    </classdef>
    <classdef name="KashidaWidthType" enumeration="true">
      <shortdesc>The kashida width type constants.</shortdesc>
        <property name="kashidaNone" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>0</value>
          </datatype>
        </property>
        <property name="kashidaSmall" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>1</value>
          </datatype>
        </property>
        <property name="kashidaMedium" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>2</value>
          </datatype>
        </property>
        <property name="kashidaLong" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>3</value>
          </datatype>
        </property>
        <property name="kashidaStylistic" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>4</value>
          </datatype>
        </property>
      </elements>
    </classdef>
    <classdef name="ComposerEngineType" enumeration="true">
      <shortdesc>The composer type constants.</shortdesc>
        <property name="latinCJKComposer" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>0</value>
          </datatype>
        </property>
        <property name="pptycaComposer" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>1</value>
          </datatype>
        </property>
        <property name="adornment" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>2</value>
          </datatype>
        </property>
      </elements>
    </classdef>
    <classdef name="ParagraphDirectionType" enumeration="true">
        <property name="leftToRight" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>0</value>
          </datatype>
        </property>
        <property name="rightToLeft" rwaccess="readonly">
          <datatype>
            <type>int</type>
            <value>1</value>
          </datatype>
        </property>
      </elements>
    </classdef>
    <classdef name="JPEGCompressionMethodType" enumeration="true">
      <shortdesc>JPEG Compression Method type.</shortdesc>
        <property name="BASELINESTANDARD" rwaccess="readonly">
          <shortdesc>Select Baseline (Standard) to use a format recognized by most web browsers.</shortdesc>
          <datatype>
            <type>int</type>
            <value>0</value>
          </datatype>
        </property>
        <property name="BASELINEOPTIMIZED" rwaccess="readonly">
          <shortdesc>Select Baseline Optimized for optimized color and a slightly smaller file size. Not supported by all web browsers.</shortdesc>
          <datatype>
            <type>int</type>
            <value>1</value>
          </datatype>
        </property>
        <property name="PROGRESSIVE" rwaccess="readonly">
          <shortdesc>Select Progressive to display a series of increasingly detailed scans (you specify how many in ProgressiveScan) as the image downloads. Not supported by all web browsers.</shortdesc>
          <datatype>
            <type>int</type>
            <value>2</value>
          </datatype>
        </property>
      </elements>
    </classdef>
    <classdef name="Assets" dynamic="true">
      <shortdesc>A collection of assets.</shortdesc>
        <method name="addFromSelection">
          <shortdesc>Creates an asset from the selected arts.</shortdesc>
          <datatype>
            <type>Asset</type>
          </datatype>
        </method>
        <method name="add">
          <shortdesc>Creates an asset from the given art(s)</shortdesc>
          <parameters>
            <parameter name="sourceArt">
              <shortdesc>The page item(s) to apply to.</shortdesc>
              <datatype>
                <type>any</type>
              </datatype>
            </parameter>
          </parameters>
          <datatype>
            <type>Asset</type>
          </datatype>
        </method>
      </elements>
      <elements type="instance">
        <property name="parent" rwaccess="readonly">
          <shortdesc>The object's container.</shortdesc>
          <datatype>
            <type>Object</type>
          </datatype>
        </property>
        <property name="typename" rwaccess="readonly">
          <shortdesc>The class name of the object.</shortdesc>
          <datatype>
            <type>string</type>
          </datatype>
        </property>
        <property name="length" rwaccess="readonly">
          <shortdesc>Number of elements in the collection.</shortdesc>
          <datatype>
            <type>int</type>
          </datatype>
        </property>
        <method name="removeAll">
          <shortdesc>Deletes all elements.</shortdesc>
        </method>
        <method name="getByName">
          <shortdesc>Get the first element in the collection with the provided name.</shortdesc>
          <parameters>
            <parameter name="name">
              <datatype>
                <type>string</type>
              </datatype>
            </parameter>
          </parameters>
          <datatype>
            <type href="#/Asset">Asset</type>
          </datatype>
        </method>
        <method name="remove">
          <shortdesc>Deletes the asset with specified id.</shortdesc>
          <parameters>
            <parameter name="assetID">
              <shortdesc>UID of the asset to be deleted.</shortdesc>
              <datatype>
                <type href="#/Int32">Int32</type>
              </datatype>
            </parameter>
          </parameters>
        </method>
          <shortdesc>Gets the first asset with specified name.</shortdesc>
          <parameters>
            <parameter name="assetName">
              <shortdesc>Name of the asset.</shortdesc>
              <datatype>
                <type>string</type>
              </datatype>
            </parameter>
          </parameters>
          <datatype>
          </datatype>
        </method>
        <method name="getByID">
          <shortdesc>Gets the asset with the specified AssetID.</shortdesc>
          <parameters>
              <shortdesc>The UID of the asset.</shortdesc>
              <datatype>
              </datatype>
            </parameter>
          </parameters>
          <datatype>
          </datatype>
        </method>
      </elements>
    </classdef>
    <classdef name="ExportForScreensItemToExport" dynamic="true">
      <shortdesc>An item that needs to be exported; for example, a document, artboard, or asset.</shortdesc>
        <property name="artboards">
          <shortdesc>Range of artboards to export [possible values: '', 'all'(default), range]</shortdesc>
          <datatype>
            <type>string</type>
            <value>all</value>
          </datatype>
        </property>
        <property name="assets">
          <shortdesc>Array of asset id to export (default:empty)</shortdesc>
          <datatype>
            <array />
          </datatype>
        </property>
        <property name="document">
          <shortdesc>Whether to export the document or not.</shortdesc>
          <datatype>
            <type>bool</type>
            <value>false</value>
          </datatype>
        </property>
      </elements>
    </classdef>
    <classdef name="ExportForScreensOptionsJPEG" dynamic="true">
      <shortdesc>Options which may be provided when exporting a document as a JPEG100 file.</shortdesc>
        <property name="compressionMethod">
          <shortdesc>Should the image be compressed.</shortdesc>
          <datatype>
            <type href="#/JPEGCompressionMethodType">JPEGCompressionMethodType</type>
            <value>JPEGCompressionMethodType.BASELINESTANDARD</value>
          </datatype>
        </property>
        <property name="progressiveScan">
          <shortdesc>Specify the number of detailed scans when downloading a JPEG file using the Progressive option as the CompressionMethod.</shortdesc>
          <datatype>
            <min>3</min>
            <max>5</max>
            <value>3</value>
          </datatype>
        </property>
        <property name="antiAliasing">
          <shortdesc>Should the resulting image be antialiased.</shortdesc>
          <datatype>
            <type href="#/AntiAliasingMethod">AntiAliasingMethod</type>
            <value>AntiAliasingMethod.ARTOPTIMIZED</value>
          </datatype>
        </property>
        <property name="embedICCProfile">
          <shortdesc>Embed an ICC profile when exporting.</shortdesc>
          <datatype>
            <type>bool</type>
          </datatype>
        </property>
        <property name="scaleType">
          <shortdesc>How should the resulting image be scaled.</shortdesc>
          <datatype>
            <type href="#/ExportForScreensScaleType">ExportForScreensScaleType</type>
            <value>ExportForScreensScaleType.SCALEBYFACTOR</value>
          </datatype>
        </property>
        <property name="scaleTypeValue">
          <shortdesc>The value by which the resulting image should be scaled.</shortdesc>
          <datatype>
            <type>number</type>
            <value>1</value>
          </datatype>
        </property>
      </elements>
    </classdef>
    <classdef name="ExportForScreensOptionsPNG8" dynamic="true">
      <shortdesc>Options which may be provided when exporting a document as an 8 bit PNG file.</shortdesc>
        <property name="colorCount">
          <shortdesc>Number of colors in exported color table.</shortdesc>
          <datatype>
            <min>2</min>
            <max>256</max>
            <value>128</value>
          </datatype>
        </property>
        <property name="transparency">
          <shortdesc>Should the resulting image use transparency.</shortdesc>
          <datatype>
            <type>bool</type>
            <value>true</value>
          </datatype>
        </property>
        <property name="interlaced">
          <shortdesc>Should the resulting image be interlaced.</shortdesc>
          <datatype>
            <type>bool</type>
          </datatype>
        </property>
        <property name="matte">
          <shortdesc>Should the artboard be matted with a color.</shortdesc>
          <datatype>
            <type>bool</type>
            <value>true</value>
          </datatype>
        </property>
        <property name="matteColor">
          <shortdesc>The color to use when matting the artboard (default: white)</shortdesc>
          <datatype>
            <type href="#/RGBColor">RGBColor</type>
          </datatype>
        </property>
          <datatype>
          </datatype>
        </property>
          <datatype>
          </datatype>
        </property>
          <datatype>
            <type>number</type>
            <value>1</value>
          </datatype>
        </property>
      </elements>
    </classdef>
    <classdef name="ExportForScreensOptionsPNG24" dynamic="true">
      <shortdesc>Options which may be provided when exporting a document as an 24 bit PNG file.</shortdesc>
          <datatype>
            <type>bool</type>
            <value>true</value>
          </datatype>
        </property>
          <datatype>
          </datatype>
        </property>
        <property name="backgroundBlack">
          <shortdesc>Should the resulting image rasterize against a black background (with value true) or white background(with value false) if it doesn't use transparency.</shortdesc>
          <datatype>
            <type>bool</type>
          </datatype>
        </property>
          <datatype>
            <type>bool</type>
          </datatype>
        </property>
          <datatype>
          </datatype>
        </property>
          <datatype>
            <type>number</type>
            <value>1</value>
          </datatype>
        </property>
      </elements>
    </classdef>
    <classdef name="ExportForScreensOptionsWebOptimizedSVG" dynamic="true">
      <shortdesc>Options which may be provided when exporting a document as a web optimized SVG file.</shortdesc>
        <property name="fontType">
          <shortdesc>The type of font that should be included in the exported file.</shortdesc>
          <datatype>
            <type href="#/SVGFontType">SVGFontType</type>
            <value>SVGFontType.SVGFONT</value>
          </datatype>
        </property>
        <property name="coordinatePrecision">
          <shortdesc>Decimal precision for element coordinate values.</shortdesc>
          <datatype>
            <min>1</min>
            <max>7</max>
            <value>3</value>
          </datatype>
        </property>
        <property name="cssProperties">
          <shortdesc>How should the CSS properties of the document be included in the document.</shortdesc>
          <datatype>
            <type href="#/SVGCSSPropertyLocation">SVGCSSPropertyLocation</type>
            <value>SVGCSSPropertyLocation.STYLEATTRIBUTES</value>
          </datatype>
        </property>
        <property name="svgId">
          <shortdesc>How object names (IDs) are generated in exported SVG.</shortdesc>
          <datatype>
            <type href="#/SVGIdType">SVGIdType</type>
            <value>SVGIdType.SVGIDREGULAR</value>
          </datatype>
        </property>
        <property name="svgMinify">
          <shortdesc>Reduces the size of the svg.</shortdesc>
          <datatype>
            <type>bool</type>
          </datatype>
        </property>
        <property name="svgResponsive">
          <shortdesc>Makes the SVG Responsive.</shortdesc>
          <datatype>
            <type>bool</type>
            <value>true</value>
          </datatype>
        </property>
        <property name="rasterImageLocation">
          <shortdesc>Should the raster images in the exported file be included.</shortdesc>
          <datatype>
            <type href="#/RasterImageLocation">RasterImageLocation</type>
            <value>RasterImageLocation.PRESERVE</value>
          </datatype>
        </property>
      </elements>
    </classdef>
    <classdef name="ExportForScreensPDFOptions" dynamic="true">
      <shortdesc>Options which may be provided when exporting a document as a PDF file.</shortdesc>
        <property name="pdfPreset">
          <shortdesc>The max string length is 255 bytes. Name of PDF preset to use.</shortdesc>
          <datatype>
            <type>string</type>
            <value>[Smallest File Size]</value>
          </datatype>
        </property>
      </elements>
    </classdef>
        <property name="documentBleedOffset">
          <shortdesc>Document bleed offset rect.</shortdesc>
          <datatype>
            <type href="#/Rect">Rect</type>
          </datatype>
        </property>
        <property name="documentBleedLink">
          <shortdesc>Document link for bleed values.</shortdesc>
          <datatype>
            <type>bool</type>
            <value>true</value>
          </datatype>
        </property>
        <method name="getIsFileOpen">
          <shortdesc>Returns if the specified filePath is open.</shortdesc>
          <parameters>
            <parameter name="filePath">
              <shortdesc>The filePath to be checked.</shortdesc>
              <datatype>
                <type>string</type>
              </datatype>
            </parameter>
          </parameters>
          <datatype>
            <type>bool</type>
          </datatype>
        </method>
            <parameter name="assetType">
              <shortdesc>For internal use.</shortdesc>
              <datatype>
                <type>string</type>
              </datatype>
            </parameter>
        <property name="assets" rwaccess="readonly">
          <shortdesc>All assets in the document.</shortdesc>
          <datatype>
            <type href="#/Assets">Assets</type>
          </datatype>
        </property>
        <method name="exportForScreens">
          <shortdesc>Export the specified document/asset(s)/artboard(s)</shortdesc>
          <parameters>
            <parameter name="exportFolder">
              <shortdesc>The folder where the exported documents/assets/artboards are saved.</shortdesc>
              <datatype>
                <type href="#/File">File</type>
              </datatype>
            </parameter>
            <parameter name="exportFormat">
              <shortdesc>The file type in which the document is exported.</shortdesc>
              <datatype>
                <type href="#/ExportForScreensType">ExportForScreensType</type>
              </datatype>
            </parameter>
            <parameter name="options" optional="true">
              <shortdesc>Options for the file type specified.</shortdesc>
              <datatype>
                <type>any</type>
              </datatype>
            </parameter>
            <parameter name="itemToExport" optional="true">
              <shortdesc>What to export.</shortdesc>
              <datatype>
                <type href="#/ExportForScreensItemToExport">ExportForScreensItemToExport</type>
              </datatype>
            </parameter>
            <parameter name="fileNamePrefix" optional="true">
              <shortdesc>String prepended to each file name.</shortdesc>
              <datatype>
                <type>string</type>
              </datatype>
            </parameter>
          </parameters>
        </method>
        <property name="start">
          <shortdesc>Start index of the text range.</shortdesc>
          <datatype>
          </datatype>
        </property>
        <property name="end">
          <shortdesc>End index of the text range.</shortdesc>
          <datatype>
          </datatype>
        </property>
        <method name="getTextRunLength">
          <shortdesc>Get the length of the first text run.</shortdesc>
          <datatype>
          </datatype>
        </method>
        <method name="getParagraphLength">
          <shortdesc>Get the length of the first paragraph.</shortdesc>
          <datatype>
          </datatype>
        </method>
        <property name="kana">
          <shortdesc>Does the Japanese OpenType support kana?</shortdesc>
          <datatype>
            <type>bool</type>
          </datatype>
        </property>
        <property name="ruby">
          <shortdesc>Does the Japanese OpenType support ruby?</shortdesc>
          <datatype>
            <type>bool</type>
          </datatype>
        </property>
        <property name="kashidas">
          <shortdesc>Kashidas attribute.</shortdesc>
          <datatype>
            <type href="#/KashidasType">KashidasType</type>
          </datatype>
        </property>
        <property name="dirOverride">
          <shortdesc>Direction override attribute.</shortdesc>
          <datatype>
            <type href="#/DirOverrideType">DirOverrideType</type>
          </datatype>
        </property>
        <property name="digitSet">
          <shortdesc>Digit set attribute.</shortdesc>
          <datatype>
            <type href="#/DigitSetType">DigitSetType</type>
          </datatype>
        </property>
        <property name="diacVPos">
          <shortdesc>Diacritics positioning attribute.</shortdesc>
          <datatype>
            <type href="#/DiacVPosType">DiacVPosType</type>
          </datatype>
        </property>
        <property name="diacXOffset">
          <shortdesc>Diacritics x offset attribute.</shortdesc>
          <datatype>
            <type>number</type>
          </datatype>
        </property>
        <property name="diacYOffset">
          <shortdesc>Diacritics y offset attribute.</shortdesc>
          <datatype>
            <type>number</type>
          </datatype>
        </property>
        <property name="overlapSwash">
          <shortdesc>OpenType overlap swash attribute.</shortdesc>
          <datatype>
            <type>bool</type>
          </datatype>
        </property>
        <property name="justificationAlternates">
          <shortdesc>Justification alternates attribute.</shortdesc>
          <datatype>
            <type>bool</type>
          </datatype>
        </property>
        <property name="stretchedAlternates">
          <shortdesc>Stretched alternates attribute.</shortdesc>
          <datatype>
            <type>bool</type>
          </datatype>
        </property>
        <property name="defaultTabWidth">
          <shortdesc>Default tab width attribute.</shortdesc>
          <datatype>
            <type>number</type>
          </datatype>
        </property>
        <property name="paragraphDirection">
          <shortdesc>Main writing direction attribute.</shortdesc>
          <datatype>
            <type href="#/ParagraphDirectionType">ParagraphDirectionType</type>
          </datatype>
        </property>
        <property name="kashidaWidth">
          <shortdesc>The Kashida Width attribute.</shortdesc>
          <datatype>
            <type href="#/KashidaWidthType">KashidaWidthType</type>
          </datatype>
        </property>
        <property name="composerEngine">
          <shortdesc>Composer engine attribute.</shortdesc>
          <datatype>
            <type href="#/ComposerEngineType">ComposerEngineType</type>
          </datatype>
        </property>
          </datatype>
        </method>
      </elements>
    </classdef>
    <classdef name="Asset" dynamic="true">
      <shortdesc>An (exportable) asset.</shortdesc>
          <datatype>
            <type>Object</type>
          </datatype>
        </property>
          <datatype>
            <type>string</type>
          </datatype>
        </property>
        <property name="assetID" rwaccess="readonly">
          <shortdesc>The UID for the asset which is unique within a document.</shortdesc>
          <datatype>
          </datatype>
        </property>
        <property name="assetName">
          <datatype>
            <type>string</type>
          </datatype>
        </property>
          <shortdesc>Deletes this object.</shortdesc>
        </method>
        </method>
        <method name="getNormalizedName">
          <shortdesc>Gets the normalized name without special characters, such that it can be used as a file name.</shortdesc>
          <datatype>
            <type>string</type>
          </datatype>
        </method>
      </elements>
    </classdef>
  </package>
Scripting
6.6K
Adobe
Valorous Hero ,
Oct 22, 2017 Oct 22, 2017
Thank you for posting this, Carlos.
Valorous Hero ,
Oct 24, 2017 Oct 24, 2017
I wonder what possibilites and uses are for this:
JavaScriptExecutionMode
When should a JavaScript debugger be shown.
JavaScriptExecutionMode.BeforeRunning  (Read Only)
Data Type: int, Value: 3
Show the JavaScript debugger at the first line of the JavaScript.
JavaScriptExecutionMode.OnRuntimeError  (Read Only)
Data Type: int, Value: 2
Show the JavaScript debugger is a runtime error occurs.
JavaScriptExecutionMode.never  (Read Only)
Data Type: int, Value: 1
Never show the JavaScript debugger. Treat runtime errors by throwing a JavaScript exceptions.
Oct 27, 2017 Oct 27, 2017
Hi Silly-V,
JavaScriptExecutionMode has been around since at least CS4, it seems to be used for testing purposes, their testing purposes.
Valorous Hero ,
Thanks, Its very helpful. (^-^)/
Oct 23, 2017 Oct 23, 2017
Thank you CarlosCanto.
MichaelK ¯\_(ツ)_/¯
Participant ,
Hey CarlosCanto,
Thanks alot for posting this.
Is the asset class and collection at the top for cloud libraries?
Dane
Hi daneJ, no, the new Assets collection refers to the assets in the Asset Export Panel.
Participant ,
Too bad. I'd sure like some methods to work with and modify the cloud libraries. When you have thousands of Library elements and much of your work involves these libraries, some scripting could really make a difference. Maybe CC 2019.
Valorous Hero ,
I have never used this, but could this be useful regarding cloud library assets?
Application.openCloudLibraryAssetForEditing (assetURL: File , thumbnailURL: File , options:any): Document
For Internal Use.
assetURL: Data Type: File
For Internal use.
thumbnailURL: Data Type: File
For Internal use.
For internal use.
Participant ,
Thanks. ya i have been looking at that for a bit, but it does not work for me.
using:
#target "illustrator"
var aiApp = app.activeDocument;
var artItem = aiApp.placedItems[0]
var location = File(artItem.file.fsName);
var asset = app.openCloudLibraryAssetForEditing (location,location);
I get the error that the third argument is illigal. however the third argument is optional,  and it is not given in my code. also i have no idea what to put in there.
in any event i'd like to be able to iterate through the elements and change their names, I dont think this method will help with that. I was thinking about digging in the xml(assuming that is xml behing it) to try to and directly make a name change there but i couldnt understand a lot of it.
Still, it would be interesting to understand how "openCloudLibraryAssetForEditing " works.
Participant ,
Oct 26, 2017 Oct 26, 2017
CarlosCanto
Do you know if the asset class and collection at the top for manipulating cloud libraries?
Thanks.
Participant ,
Thanks for posting this Carlos!!
Looks like they changed the interface for "TextFrame.textRange.justification.CENTER" enumeration? My scripts are throwing an error when trying to " myDoc.textFrames.textRange.justification = Justification.CENTER;"?
Cheers,
Scott
Hi Scott, it works fine here with Win10, CC2018.
change this
you're missing the index, perhaps that's the problem?
myDoc.textFrames[0].textRange.justification = Justification.CENTER
Participant ,
*** Sharing the solution in case anyone sees this problem. ***
Hey Carlos, thanks for the reply and I found the issue!
So, you were able to create a textFrame object, and set the parameters WITHOUT assigning any content:
    // create number textFrame
    var artBoardNum = myDoc.textFrames.add();
    // sets style on number textFrame
    artBoardNum.textRange.characterAttributes.fillColor = fontColor;
    artBoardNum.textRange.characterAttributes.size = fontSize;
    artBoardNum.textRange.characterAttributes.strokeWeight = 0;
    artBoardNum.textRange.characterAttributes.textFont = fontStyle;
    // BELOW LINE WILL NOT WORK!!!
    artBoardNum.textRange.justification = Justification.LEFT;
    // assign number to textFrame object
    artBoardNum.contents = artboardNum.toString();
Solution: You have to assign content to the textFrame BEFORE changing the justification property!?!?
    // MOVE AFTER CONTENT HAS BEEN ADDED?
I was having the same issue. Thanks so much for posting the solution!!
Valorous Hero ,
Holy moly I thought you were the same person. !!
Advocate ,
Jan 29, 2020 Jan 29, 2020
Really great, how did you found this data?
its 2020 and they still have their official docs at 2017?!?!?
Advocate ,
Call me crazy but why doesnt have antiAliasing any effect? i changed it to ARTOPTIMZED or NONE, makes no difference. Also checked SCALEBYRESOLUTION. its still looking jagged?
Advocate ,
setting it to Type does work, but when we use the export screen function Art simple works and is smooth. But it is now when using it with scripting
jpegParam.antiAliasing = AntiAliasingMethod.TYPEOPTIMIZED;
See below the 3 versions both None and ArtOptimized look exactly same
NoneNoneTypeTypeArtArt
Jan 30, 2020 Jan 30, 2020
it's a bug, fortunately TYPEOPTIMIZED works.
Advocate ,
Jan 31, 2020 Jan 31, 2020
Indeed, i was thinking the same that it would be a bug. I was going crazy over it.
Wonder why 3 years after this post its still there or no one posted it? Not sure no one posted a bug about it, but i did see this piece of code in some other posts. But on the other hand, im not surprised. I dont know where you got all the data/info from shown in the first post. This data is nowhere on there official docs. But hey, those date to cc 2017, written before or around 2016. All the data is pretty much older i guess, not much changes every year.
So question now, how did you come by all of this new data, where did you find this?
data comes from the Object Model Viewer, you can open it from the ESTK's help menu. There's is an xml document the actual data gets pulled.
