The problem I am having is that Acrobat isn't formatting the cells properly. If exporting to Excel has seemingly random columns, then I can't actually use the data.
Is there a way of choosing how the data is placed into cells?
Hendrik
I have discovered that if I edit convert the PDF to a screen shot and then crop out all the confusing layout, that I can get useful columns and rows, but only on a page by page basis. So every page I scan has to processed by hand. The negative numbers are not being converted to negative numbers in Excel.
In short, I am doing the processing of the data. It is actually faster for me to copy the document by hand into a Excel spreadsheet.
In order for this to be a useful conversion to Excel, the converter needs to trim the blank space off the front and rear of the text strings and then convert the text into a meaningful number if the text indicates this is what needs to be done.
I would like to cancel my service, how do I return the software and get my money back?
Hendrik
Hi Hendrik,
Sorry for the delay in response.
I have checked that you have already contacted the team to inactive the service.
We would like to rectify the issue you were experiencing with the conversion of PDF to Excel.
If you can share the PDF file with which you are experiencing the issue, we would like to check it on our end.
I have sent you a private message with the details where you can send the file.
Let us know if you need any help.
Meenakshi
I am having the same problem here. I don't want to continue the service like this. Please can you email REMOVED so we can rectify? Perhaps I am not selecting he right settings?
David
[personal information removed per policy - https://forums.adobe.com/docs/DOC-3731]
[This is an open forum, not Adobe support, please do not post personal information]
[When a Staff person asks for private information hover your mouse over their name]
[you may then click the Message option in the popup window to send a private email]
Hi D.caldwell,
Could you please confirm if you are experiencing issue in exporting PDF to Excel.
If yes, please let us know what happens when you export PDF to Excel.
It will be helpful if you can share both the files, PDF and the Excel file that you get after exporting
You may refer the steps provide here to share the files: How to share a document
Also, try once to export PDF online here https://cloud.acrobat.com/exportpdf
Check if this works.
Let us know if you have any questions.
Meenakshi
