Just updated to the 2018 version of Photoshop CC.
And then found out that the surface blur filter is not working correctly.
- I get like 5-6 1px wide vertical lines across the layer as a result. rest of the layer gets transparent (was a fully "pixel filled" image layer before)
- changing values (threshold / blur radius) does not do any difference. Only when values are very high, the layer stays "pixel filled", but gets unicolor due to the high blur radius)
- deleting prefs + reinstalling photoshop did not solve the problem.
My Machine:
MacBook Pro 15" mid 2015, 2.2 ghz, OS X 10.11.6
Anybody else got this problem?
Thanks for answers!
David
PS: Median filter works (both were "performance improved" according to the update / patch notes)
Hi All,
This issue should be fixed in Photoshop 19.0.1 which was just released.
If you don't see the Photoshop update in your Creative Cloud application, then click in flyout in upper right corner and choose "Check for App Updates".
Please let us know if you continue to face this issue in the new version.
Thanks for your patience.
Akash
Moving to Photoshop General Discussion​
What is the image mode and bit depth of your image?
How big is the image in terms of pixel dimensions?
Could you post a screenshot?
You've tried on other files?
image is:
- RGB, color profile eciRGBv2
- 6925x4623px total
- yes, tried other files. always the same, filter seems generally broken.
attached are three screenshots:
#1 no filter applied, original material at zoom 100%
#2 filter applied as intended, shows the broken result (settings: threshold 13, radius 90)
#3 filter different settings. at some value filter works, but that setting is, of course, not what i want to use! (if is slide up to threshold 86, the filter is working. 85 and below always gives the 1px lines... radius stays at 90.)
oh i forgot: bit-depth is at 8-bit.
best + thanks
david
Am having the same issue...
Use this filter in an automated process and it now breaks.
I debugged the process and it is the Surface Blur step that fails.
Image goes white with thin reddish vertical line.
Appears to be an issue with 8-bit images as when changed to 16-bit, all is well.
But then Filter gallery won't work with 16-bit image...
I wish I had left CC 2017 installed
Hope that helps you and Adobe...
Kind regards, Pete
Hi
I've just tried this on a variety of images and couldn't replicate it.
I wonder if it could be GPU dependant. I am using an AMD HD7970 3GB card here with the current 17.10.1 driver.
There have been one or two other graphic issues reported in this forum in the last couple of days, using NVidia's latest driver which were resolved by rolling back the driver. It may be worth a try if you are using NVidia GPUs.
Dave
Hi Dave,
Am using AMD Radeon R9 M395X 4096 MB - Not nvidia.
Am on late 2015 iMac with 32gb ram - 1867 MHz DDR3.
Intel 4GHz i7
Not sure I can change the drivers.
Here is the system report
Model Name: iMac
Model Identifier: iMac17,1
Processor Name: Intel Core i7
Processor Speed: 4 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 32 GB
Boot ROM Version: IM171.0105.B26
SMC Version (system): 2.34f2
Graphics:
AMD Radeon R9 M395X:
Chipset Model: AMD Radeon R9 M395X
Type: GPU
Bus: PCIe
PCIe Lane Width: x16
VRAM (Total): 4096 MB
Vendor: ATI (0x1002)
Device ID: 0x6920
Revision ID: 0x0000
ROM Revision: 113-C905AA-799
EFI Driver Version: 01.00.799
Metal: Supported
Displays:
iMac:
Display Type: Built-In Retina LCD
Resolution: 5120 x 2880 Retina
Pixel Depth: 30-Bit Color (ARGB2101010)
Main Display: Yes
Mirror: Off
Online: Yes
Automatically Adjust Brightness: Yes
Connection Type: DisplayPort
I hope that helps…
Be good to see it fixed.
Pete
My apologies for my mistype. I meant to write "can't easily change".
If surface blur is important, until this is resolved, you can install CC 2017 on the same PC as CC 2018. I have three versions installed here. You can do that from the CC desktop app.
Dave
did the same thing as an interim solution and re-installed CC 2017.
well, graphics driver problem then? hope it will be fixed in a patch then!
best,
david
Did you check your graphics driver version ? It ​may ​be the cause.
Dave
No idea on whether and how to determine that could be connected.
my graphics is standard stuff, i cannot really change things there on my macbook pro. all hardwired.
Intel Iris Pro:
Chipset Model: Intel Iris Pro
Type: GPU
Bus: Built-In
VRAM (Dynamic, Max): 1536 MB
Vendor: Intel
Device ID: 0x0d26
Revision ID: 0x0008
Metal: Supported, feature set OSX_GPUFamily1 v2
Color LCD:
Resolution: 2880 x 1800 Retina
Framebuffer Depth: 24-Bit Color (ARGB8888)
Main Display: Yes
Mirror: Off
Online: Yes
Rotation: Supported
Automatically Adjust Brightness: No
Might be helpful to the Adobe developers.
Best,
David
btw updated to High Sierra OSX 10.13 but that did not solve things either.
d.
Hi David - I hadn't realised you were using a Mac. It is the Windows drivers that you can easily change
Dave
Dave, that's a helpful hint for a short-term workaround but would be good to see this fixed really - My automated workflows are broken and I don't want to have to rebuild them every time I upgrade or it becomes self-defeating... If you get my meaning... Pete
I tried that but my computer is still opening CC 2018. I tried uninstalling 2018 and just reinstalling 2017 and still same issue.
Yes... I am running on a mac. I reinstalled Photoshop 2017 and now I have to make sure that I open files in PS17. This works though so I have a fix until they update PS18. So make sure that you are in PS17 and then use the open menu to open files.
Ben
I experience the same issue with Surface Blur. All the other Blur filters work. I turned off the GPU acceleration in the preferences and restarted Photoshop but unfortunately this did not fix the problem. It looks like Surface Blur is broken on some configurations.
MacBook Pro mid 2017
Radeon 560 GPU
running High Sierra.
Is there any news on this?
I'd rather be using the latest Photoshop rather than having 2 versions that I have to move between...
Are we likely to get a patch soon?
Thanks in advance...
Pete
Broken! Not working for me either. Image does not change at all, or completely disappears.
Using Macbook Pro 2016 Sierra 10.12.2.
Have tried 16bit and 8bit.
Ross
Still no update... Still not working on 8-bit images.
Same problem here. Surface Blur not working. I will reinstall cc17 until CC18 Behaves better.
Radeon Pro 580 8192 MC Graphics card.
same here, unusable under 105 threshold. waiting for a workaround or a fix.
btw the problem is only when I apply the filter to a non locked layer, like the background layer.
