I'm getting "Error 1220: Illegal Argument" for this line.
textRef.textRange.justification = Justification.CENTER;
If I comment it out the script runs fine. This was working fine before I updated to CC 2018.
Does anyone have any idea why this is throwing an error now?
The TextRange object doesn't have justification, it's inside the textRange.paragraphAttributes property. But this doesn't really answer the question -but try it out?
I tried this out:
textRef.textRange.paragraphAttributes.justification = Justification.CENTER;
Exact same error unfortunately.
Thanks for replying!
It seems work fine in Illustrator CC(ver.22) like below.
check your textRef variable when you get an error.
hmm...both of these work on Win10, CC2018
var idoc = app.activeDocument;
var sel = idoc.selection[0];
sel.textRange.justification = Justification.CENTER;
sel.textRange.paragraphAttributes.justification = Justification.CENTER;
Found the solution here.
Re: What's New in Illustrator Scripting CC2018
I guess the text area needs to be populated before changing paragraph attributes in cc2018.
Thanks for the help.
