hi
i'm running photoshop cc under sierra last built
i select scratch disk , my imac has 32gb
under windows it create a file called Photoshop Temp92915140 about 965 MB
under sierra i can't find such file , i have 2 scratch disk without any file while photoshop is running
can you tell me why?
where does it store this file?
thanks
and ps it's off topic
about photoshop cc where can i find extra plugin like HSB/HSL
is there a way to run bridge cc in full screen ,i have always select the maximize icon to have it in full screen
Here's where Photoshop's temp files are kept on the Mac: macos - How to recover unsaved PSD file on MacOSX - Super User
~/Library/Application Support/Adobe/Adobe Photoshop <version>/AutoRecover
When you close Photoshop, they are gone.
hi
i guess i was not clear
first file save option -> automacly save recovery information every x minutes is disabled
i 'm talking about scratch disks
i have 2 ssd ( 2 solid state disks )
in the first disk i have sierra and photoshop , lightroom and bridge
the second ssd i use for scratch disk
well in the photoshop cc option in the scratch disk i have selected the second ssd (it's almost empty)
run photoshop cc , and while photoshop was running with finder i gave a lot to the second ssd , there is nothing
Maybe the scratch file is hidden, or is deleted. (On a Mac, an app can delete a file it is using, and it goes away when the app quits; this is very useful because it is certain to be cleaned up).
hi
do you run photoshop under osx ?
i kept photoshop running , the point is that i bought a second ssd only for scratch
and i have used an utility to show me the hidden files
i can't find any file create by photoshop cc 2015 & 2018
can somebody help me?
thanks
As I said you might not find them. Why not just monitor free space to see if it is being used up.
Hi
may i know if you are a mac user?
i can't believe that nobody knows where does it store the scratch disk on osx
thanks
hi
the point again is thay i spent money for this new ssd
maybe an adobe team developer could answer
You can see the hidden files on your ssd by using Text Edit, clicking File>Open then navigate to the ssd and press Shift+Command+.
That's Shift+Command+Period
after a few seconds all the hidden files should appear.
Hopefully somewhere is a Photoshop Temp file with a bunch of numbers after it like
Photoshop Temp432977
hi
i did it , can't find any photoshop temp* files
have you tried it? have you find them? can you post a screenshots please?
i have even used easyfind
thanks
that's my scratch disk
Did you open the TemporaryItems folder?
I forgot to add you need to have photoshop running when you look for it Scratch Disk file.
When you quit photoshop, the Scratch Disk file gets deleted.
hi
i can not open that folder
but can you check on your mac and tell me please where does it save scratch files?
yes i know i need to keep photoshop open and running
thanks
Hi Jeff
can I ask you ? do you use el capitan or sierra?
because i guess there is a bug or in sierra or photoshop cc, i have monitor with DriveDx (it's a smart program) and at every time i run photoshop , under total write ,there is 1gb more
thanks
