What is the time that is displayed in the 'my photos' section in LR CC? I took a few pictures on Tuesday and the 'info' section shows the correct time, but the 'my photos' section shows it 6 hours behind. Am I missing a setting somewhere?
I believe you are asking why the times are different in the top and bottom screenshots.
I'm still digging my way through the new Lightroom CC, but I believe that the top screenshot is the time you imported your photos into Lightroom CC and the bottom screenshot is the time your photo was actually taken
That is correct, is wish to view your photo's in chronological order click the "By Date" tab.
Just did a test on it and it's the import time. The issue is that the time is wrong. I can't seem to figure out why it's selecting 6 hours earlier as the import time.
That is rather confusing. You might try uninstalling and reinstalling the software! Make sure your time is set correctly on your computer as well!
Is your device set to the correct time zone ?
It is set correctly. It's not a big deal but it is interesting. I'm guessing no one else has this issue?
I personally am not having this issue. If your time is set correctly on your computer, did you just try a simple uninstall and reinstall?
Correct. I'm really trying to determine why they are different. I can tell you with pretty good certainty that I was not importing images at 3:30am:) What's interesting is that if I import an image now, it'll show the relative difference in minutes (i.e. 5 minutes ago) and it will be correct. It's when it I wait till later on that the time will be off. Not a big deal; just curious.
