Hello all ,
Please i want to know if there is any way to link a point to null for example : I create a square and it has 4 points and I want to link one of his points to Null and With the possibility of controlling the path of other points in normal
test file .ae
https://1drv.ms/u/s!AsWsbi63c96Kt1EKjadl-CsKC4LQ
Thank you for understanding what I want
I motion the characters and I need to manipulate the path and move the keyframe animation in frame by frame
This feature is excellent for connecting in but I want to solve the remaining points and manipulate them freely
Please Solution We have waited for this feature a lot
Nothing specific to solve.Unless you explicitly manipulate the values, the createPath will simply reuse the original path. You just may need to copy the arrays and points to your own lists and insert the programmatically modified point at the right position in the array.
Mylenium
https://forums.adobe.com/message/9931338?et=watches.email.outcome#9931338
Here the problem page will wait for the solution and update this feature
Thanks for the post
