As per the above, I updated Photoshop Elements 12 to PS Elements 15 a couple of months ago. I had previously downloaded Premiere Elements 14. I went to Open Premiere Elements on my Windows 10 laptop for the first time since updating PS Elements only to discover the even though it showed the Premiere Elements icon, it loaded PS Elements 15? On checking the preference tab, it clearly indicates Premiere Elements which is not the case. Any help would be appreciated.
Delete the shortcut and just create a new shortcut for the desired program.
Alternatively, right click on the shortcut and change its properties so it opens the desired program.
Thanks for your quick response. I did as you suggested but no luck. If I hit the start button both Elements and Premiere Elements are shown. If I double click on Elements 15, the program loads. When clicking on Premiere Elements, nothing happens. I then went back to the start button and typed in Premiere Elements. The Premiere Elements App appeared. Double clicking on the App did nothing?
I would uninstall and reinstall it.
Thanks again for your prompt response. I did as you recommended and uninstalled Premiere Elements 14 and reinstalled it. When I single clicked on the icon it indicated the program to be Premium Elements 14. On double clicking the icon to launch the program I was once again dismayed that the program is not what was downloaded this time it was PS Elements 14 not Premiere Elements 14. I then clicked on Control Panel and checked downloaded programs. It was clear the program downloaded earlier today was Premiere Elements 14. Any ideas?
Are you downloading from here:
Download Adobe Premiere Elements 2018, 15, 14, 13, 12, 11, 10
