There was a problem reading the layer data. Read the composite data instead?
Oct 30, 2017 Oct 30, 2017
I can not open my PSD file
It is about 180MB
Never had a problem and then all of a sudden "There was a problem reading the layer data. Read the composite data instead?"
Help What do I do!?
17.4K
Nov 01, 2017 Nov 01, 2017
Hi Gatostreet,
Please refer this discussion There was a problem reading the layer data. Read the composite data instead? and let us know if that helps.
Akash
Adobe
Hi Gatostreet,
Akash
Aug 11, 2021 Aug 11, 2021
clean cache and try again
Dec 31, 2019 Dec 31, 2019
This isn't a solution to a problem you should fix. Every time this question gets asked an Adobe support person directs us to your answer as if that is actually of any use. Fix the damn problem and issue an apology for thousand of hours of labor your customers have LOST.
In all the years I've used Photoshop daily (which is many) I've never had a corrupt PSD - not even once. Maybe I've been lucky, but I also believe in creating my own luck. I always save to a local hard drive - never to a network or removable drive. Files can be copied to the network later if required. This is standard advice from Adobe.   https://helpx.adobe.com/uk/photoshop/kb/networks-removable-media-photoshop.html
I also save incrementally (Filename001.psd, Filename002.psd etc). This is mainly to protect against errors on my part but would equally protect against a corrupt file if it happened.
I really do feel for those with corrupt files, who have lost work, but the impact should be no worse than opening the previous incremental file.
Dave
Mar 16, 2022 Mar 16, 2022
Hi Weston, try freeing up storage space and closing the PSD files you are not using.
Basically, the file needs enough RAM to read the layers.
