[Moderator moved from The Lounge to Photoshop General Discussion.]
Hi there I am having a problem with photomerge making a panorama.
I select the images and then try to run but it stops with only one picture not
completing panorama
here is a screenshot of where it gets to
I am using photoshop cc 2018 on a dell xps 15 9560 with 32 gig ram
Hi cameronl,
Please refer the below article to follow the steps to create panorama in Photoshop CC 2018
Create and edit a panorama in Photoshop
Let us know if that helps.
Mohit
it still doesn't work for mine.. it shows exactly like what one of the image looks like in layer 1 and an invisible ​Photomerge ​labeled layer
How do your initial frames look? You need about 40% solid overlap.
Water or sky don't count as overlap. Both are moving. Psychologically you see water as a "thing", but in reality there's nothing for the algorithm to work with.
Also make sure you don't have too much parallax error. Ideally you should mount the camera on an adjustable rail (on a tripod), so that the camera rotates around the optical center of the lens.
Do you have another set of images to try it with? You need to determine if the problem is with the images not overlapping enough, or with Photoshop not performing correctly.
Thanks for your feedback everyone in answer to the things raised, I have used sample sets of images from various sources on the net and 2 sets of my own images from different cameras with the correct amount of overlap all of which stitch successfully in previous versions of photoshop. So for the moment I do not have a fix
I've just done the latest update and all is working well now 🙂
