Downloaded and updated Photoshop and InDsign:
Photoshop won't launch when going through Creative Cloud - when using Windows Start Menu: Application was unable to start correctly (0Xc0000022)
InDesign just mentioned crash info, to send to Adobe
Please advise
Txs
Wilhelm
1. update your graphics card driver
2. try running ps as admin: right click the ps exe>'run as admininistrator'
Thank you, that works !
Merci,
Wilhelm
[Moderator Note: Personal information removed. Please remember to turn off signatures when replying to forum posts via email.]
you're welcome.
Another question:
I have the same issue to run InDesign, it does not start... when trying to start it via Admin, then it appears to start, but takes incredibly long, and then is “non-responsive” .... do you know a way I can get that resolved?
Wilhelm
CONFIDENTIALITY NOTICE: This message and any attachments may contain information that is confidential. It is intended for use only by the named recipient(s). If you are not a named recipient, please notify the sender immediately, and do not use this message or any attachments for any purpose, or distribute or disclose its contents to any person, or copy or store it in any medium.
reset your preferences - https://forums.adobe.com/thread/526990
(p.s when using the adobe forums, please mark helpful/correct responses, if there are any.)
Thanks for the quick response... I did that, but makes no difference.... upon re-launching, I could not see the two folders (InDesign Defaults; InDesign SavedData) being re-written either...
Any other suggestions?
Also, will there be a time when I can run the programs “regularly” and not as “admin”... that is a bit annoying...
Wilhelm
