With the 2018 upgrade the CTL+ATL shortcut no longer works to change brush sizes on WIn 10. I am using an Intuos Pro.
I read on these forums for the 2017 upgrade a similar thing happened but you could roll back the wacom drivers; I went as far back as 6.3.16-2 and 6.3.19-3 and neither worked.
When I Use the combination with the Wacom it give you the move tool and duplicates your layer when you try to scale.
This is the most important feature/combination of anyone who uses this for any type of painting or retouching.
My workflow is entirely compromised.
Hi All,
We have identified this issue a bug and our engineering team working on this issue and looking for the fix. You can refer the feedback link: Photoshop CC 2018: CTRL+ALT+Z not working properly | Photoshop Family Customer Community
Mohit
Having same problem, If you find away to solve it pls comment.
I will, please let me know if you find a solution as well.
~ see my post below. Hope it helps.
This works:
Hi dougamebook,
Thanks for sharing the related discussion.
Mohit
Hi All,
Mohit
OK, I have it working again.
I noticed that my surface three had the old drivers (6.3.25-3) and worked. So I rolled my desktop drivers back to 6.3.25-3. But it still didn’t work, so I figured perhaps it was my older keyboard. I then switched keyboards to a newer one I had here at the office. It is a newer Microsoft wireless. I restarted and it works.
I would go so far as to say it will probably work even if I upgrade the Wacom drivers. Although at this point I have gotten behind on some work so I will test it when I have the time.
Also: You can get the 6.3.25-3 drivers by copying the current link on the Wacom driver page and changing the last variables.
Like this: http://cdn.wacom.com/u/productsupport/drivers/win/professional/WacomTablet_6.3.25-3.exe
AHHHGGGHH!!!!
This seemed to work but then upon rebooting (without upgrading drivers) it stopped. ???
