I have used Adobe Export PDF to convert several PDFs into Word Documents. Today after 5 attempts to upload and five error messages "Upload Failure", I still have no converted document. Anyone else having problems with the Export service? I use a PC with Windows 10 OS. My Adobe Reader plan is Adobe Export PDF.
Are you using the interface built into the free Adobe Reader, or are you uploading directly? If it's Reader, then try to upload to the service: http://cloud.acrobat.com/exportpdf - does that work? In my experience, uploading directly is a lot more reliable than using Reader.
Hello Karl,
Thanks very much , you saved precious time of my day!
It works now...and it works much better straight from cloud acrobat than acrobat reader.
Best regards,
Marinaldo
We are sorry for the inconvenience caused to you.
1.Please let us know the Reader version from Help > About Acrobat reader DC. Update to latest version from Help > Check for Updates
2. Are you experiencing this for a particular file ? Please share the file if issue is file specific.
Please check if you are able to successfully export from online service: https://cloud.acrobat.com/exportpdf
Kindly share a snapshot of the error message you observe?
Poorvi
I have successfully been utilising the convert to excel function for quite some time. Now it has stopped working with error message:
The file has not been processed.
An error has occurred which sopped
the processing of the PDF.
What do I need to do to fix this problem?
