need a beats workstation under $6000 to $7000 for Premiere, AE and c4d.
my work is edit music videos and some roto also,
animation 2d 3d and lot of colour grading....
my current system's specs are..
MacPro 2013
3.0GHz 8-core with 25MB of L3 cache
32GB (4x8GB) of 1866MHz DDR3 ECC
512GB PCIe-based SSD
Dual AMD FirePro D700 GPUs with 6GB of GDDR5 VRAM each
now i want to switch over windows based workstation please suggest in beetweeb $6-7k
what about the new dell's workstations..
what about the new dell workstations
https://www.dell.com/en-us/work/shop/cty/pdp/spd/precision-7820-workstation...
https://www.dell.com/en-us/work/shop/cty/precision-5820-workstation/spd/pre...
both are new technology based....
and hp's coming son z series
Z4-Z6-Z8
budget is $6000 to $7000
Moved to the Hardware Forum.
thanx... @Prew
You would be much better off going to i of 3 vendors that specialize in Audio/Video computer building and frequent this forum--alphabetically.
what about the new dell and hp workstations.....
We on this forum have rarely found an off-the-shelf configuration that is truly optimized for Adobe Premiere, After Effects and Audio packages. They sometimes have conflicting requirements.
@bill gehrke so which specs system i should make for my work.??
Well the problem is: I know nothing about your software except the Premiere side of things. For instance a great Premiere configuration is not necessarily a great AE computer, then factor in all your other software is way beyond this Premiere Pro Hardware Forum. That is why I suggested that you go to experts that can do a proper job by asking you specific questions AND provide technical support on that hardware software configuration. The quality of support for your software that the HP's and Dell's could never give you.
