OK so about a month ago I started working on this animation, everything is going fine till I start to receive a unable to save message, now the second that message popped up I copied all of my frames at the time and placed them in a new document and tried saving right away but the message appeared again. This didn't bug me too much at the time because even though it said it was unable to save, it still saved my work,but whenever my document would autosaves/auto recovery, it would take 5mintues to try and save, during that 5mintues I can't doing anything with Flash, and then the unable to save message would appear, the worst part it would autosave/recovery every 10mintues, I tried to increase the auto save time and even turn it off but it would still save every 10 minutes. Another issue I am having with Flash is the out of memory issue, the animation I am working on has around 12000 frames of audio, I am currently at 4000 frames and I am starting to get issue saying I am out of memory, Whenever I open the file back up it takes way longer than usual to open it, but whenever I try to open up a file with the main one I am working with, flash sometimes gives me a message saying error opening up this file, This only happens when I open it with the one I am working with, whenever I open the other file alone, it works fine, but it got worse the more I work on my file, the next day when I comeback to work on it, I can't open it properly, the work space looks all corrupted, some times it gives me a message that this file could be damaged,and sometimes it doesn't open at all. I recently was researching about this issue and apparently I had to go find the jvm.ini and change the default number 128xmx.I gave it a ridiculously number like 14000xmx. But strangely it works I can open the file I am working on and it looks okay, and I can open another file next to it with out problems sometimes. I fill like I am slowly getting there on fixing that issue but I don't think the XMx should be 14000, I have tried lower the number but they don't work.The last issue is because I have set the XMx to 14000 I keep getting a message saying "error initializing Java run time environment" everytime I start flash, I can't export publish preview because of the memory problem. I don't know what to do this is frustrating. All I want to do is draw but with all these issues I see no point to keep going to work on my animation, does anyone have advice?or should I just quit
For anyone following along (though it looks like nobody is), Tristan has drawn his animation just as timeline vectors. Each time there is a key frame in each layer, that's like having a completely different drawing again. There are a lot of keyframes in the animation, and so although the file is only about 240 MB (72 MB of which is the sound), there are perhaps millions of vectors being loaded into memory. Hence needing 14GB of virtual memory to open it.
I've given him some advice, mainly that us
...Copy link to clipboard
A good number to try for jvm.ini is 1024. That's already 8 times the default for CS6, so should help quite a bit. Setting it to something too high could cause the system to run out of memory.
One thing to think about doing is to take say the first 6000 frames and copy those into a new FLA. If that succeeds you copy the remaining frames into a second new FLA. Then close the original FLA it without saving. So, you would have:
whateveryoucalledit.fla
part1.fla //the first 6000 frames of whateveryoucalledit.fla
part2.fla //the remaining thousands of frames of whateveryoucalledit.fla
You can always go back to the troublesome huge FLA to get anything that didn't copy across ok, but you would then start to work on the two new FLAs.
A lot of things have been improved since CS6, especially with auto recovery. But some of the CS6 features were dropped in later versions, or work in a different way. But it's worth thinking about getting a more recent version to work with.
Once you have finished the animation you could copy the part2.fla frames and paste them at the end of a duplicate of part1.fla, and hopefully be able to save out a fresh complete FLA.
When I switched it to 1024xmx I still get the Java Runtime error, and I can't copy and paste multiple frames now into a new file or even the one I am working on, flash cs6 won't allow me anymore, I wanted the recent version of flash but the only one I get offered in my app preferences in creative cloud is flash cs6, I am guessing my computer can't handle it or something but I don't know how to get newer versions. Thanks for your help though Colin.
If you have somewhere to post the FLA online, where I can get it, I could try the copying idea for you.
I have sent you a message with a link. Thank you
I saw a message from you earlier, but it was empty. You can send a link straight to me at colinholgate at gmail dot com.
I've given him some advice, mainly that using symbols is a good thing.
For what it's worth most professional animation houses use Flash or Animate to animate individual scenes and not an entire film in it. To make an entire film in Flash in one shot would indeed bog it down and cause the errors your seeing. I recently made a 5 minute animated piece but even that was bogging a bit here and there. I know this doesn't necessarily help after the fact but you should make each scene it's own file and then export them to video files and edit in your video editor of choice.
