Hi, since the last update in Photoshop CC 2018, i can't target the texture of my .obj model as explained in this tutorial : 3D painting in Photoshop
Can you help me to fix this issue ?
Vincent Lagardère.
I explain a little more : I use to open .obj first then the texture by double-clic on layer panel. Normally if I use a split view of both, I can see the position of my brush simultaneously. And if I made change on .psb file of the texture and quit with save, the .obj don't update.
Hi
It still works here on CC2018:
You could try resetting preferences and see if it resolves
Dave
Hi Dave, I reset my preferences it seems a little better and the update of .psb works now. BUT, and it still one of my biggest issues, I can't see the position with cursor (in 2.) where I work. (The capture was made with a co-worker who don't update his version.).
Here is the red line instead of a cursor that I see with photoshop 2018 CC, only on .obj view when I work on .psb (plane texture), when I work on .obj I can't see where I work on texture file..
Hi
I see this in CC2018:
Or the other way round :
Dave
Ok, that's what I need... How could I restaure this ? Is it possible that the french edition have some kind of bug. And how could I fix it ?
Possible - but try another couple of things first. Are you main 3D layer and your texture psb set to differing bit depths? If so try setting them the same , or make a quick model with them set the same, and see what you get.
Dave
Both are in RVB/8bits. But one thing is strange (and seems due to new tools), the size of my brush are differents. On .obj my brush 13px are huge but on the .psb the size 13px are smaller (about x5 times).
Hi ,
Although I could not reproduce your issue , you are seeing something wrong. Can you raise the issue at the link below where it is more likely to be seen by Adobe staff (this forum is user to user). Please give your system details and the version (and locale) of Photoshop
Photoshop Family Customer Community
Dave
Thanks Dave for your help.
