Frame Animation - Adding An Object that Doesn't Start on First Frame - PS CC
Nov 04, 2017 Nov 04, 2017
Hey Guys - First post here, so let me say thanks in advance for your help, and your patience. I did a search in multiple places and couldn't find the answer.
High Level
I'm trying to figure out how to make a gif and add content to it in PS CC. I have figured out how to get a layer to stop when I want it to (by keeping it visible until it reaches the desired frame), but I'm having trouble figuring out how to add a layer that doesn't start at the beginning.
Detailed Description of What I'm Trying to Do
I'm trying to animate a gif of the Three Amigos Salute with different faces. Powerful stuff, I know.
https://giphy.com/gifs/sY1yvrxROgCM8
So I figured out how to add the faces (first faces). The problem is, towards the end, the characters turn their heads, requiring new "faces" (second faces) to layer on top.
I figured out how to make the first faces stop when the head turns. However, when I add the next layers with the second faces, they play from the beginning. I only want them to start at a certain frame.
Is there a way to accomplish this?
Thank you so much,
Jeremy
235
Community Expert , Nov 04, 2017 Nov 04, 2017
As far as I know, when you add the frame, it would be best to make sure "New Layers Visible in All Frames" is unchecked. You will then have to go through each frame of your animation and turn on the visibility of the new faces. I guess you could leave that new layers check and turn off visibility in all the frames where you don't want it - whichever has the least amount of frames to change.
Adobe
Just found out that you can select a range of frames, then turn the visibility on or off on a layer, and it will affect only those frames selected.
Nov 06, 2017 Nov 06, 2017
Thank you - I discovered this (of course) soon after I posted it. Thanks for your help and putting out the right answers for anyone else as dumb as I am.
Not a dumb question, and I too often find the and see right after I ask about it.
