Join us for an upcoming in-person Adobe Target Skill Builders event ~~> We're hosting these live learning opportunities to equip you with the knowledge and skills to leverage Target successfully. Learn more to see if we'll be coming to a city near you!
SOLVED
Network - Domain Name rule for ip based
Avatar
Level 2
I am creating a rule based on network details i.e
  1. Audiences > Create Audience >Add Rule > Network > Domain Name
and I am within my in network connection but I am not seeing the experience. I see it for some(including me) but not for others, also network wifi.
Please let me know how i can achieve this.
1 Accepted Solution
Avatar
Correct answer by
Employee Advisor
Hey Prarthana,
I'd use the mboxTrace debugging tool to see what is returned for your IPs for domainName and then adjust your audience accordingly. Here's the help doc on using the mboxTrace tool: Troubleshooting Content Delivery​. You'll also need to get the auth token (described in the doc). You can find it in Target > Setup > Implemenation > Generate Authorization Token.
Then load the page where Target is implemented and open the developer tools > network tab to view the mbox request response. In Chrome it will look like this:
Also, if you know other specific IP addresses that you want to include you can use the "&mboxOverride.browserIp=X.X.X.X" debugging parameter to spoof Target into thinking you are coming from a different IP and thereby see what it's domainName is too. Just add that parameter to your page URL (use a "?" instead of the "&" if there is no "?" in your page URL). Hope that helps.
Avatar
Correct answer by
Employee Advisor
Hey Prarthana,
Avatar
Level 2
Hi Ryan, I do not see Domain name in my preview:
And do i still try -
or use profile script?
Avatar
Level 2
Please help. Waiting to hear back.
Avatar
Employee Advisor
Hi Parthana,
It looks like you have to include the mboxOverride.browserIp parameter to get the GEO data to show in your trace. I hadn't realized that before. You can use your own IP in the mboxOverride.browserIp too.
