Hi there
I have a new computer with the following specifications:
- Windows 10 64bit
- NVIDIA GeForce GTX 1080 Ti and 1050 Ti (Driver 388.00)
- Intel i9-7980XE
- 128 GB Memory
- Samsung SSD 960 PRO
- 6 Monitors
All applications work fine, for example Adobe Lightroom Classic CC
But while starting Photoshop CC 2018, it causes BlueScreen with different messages:
WHEA_UNCORRECTABLE_ERROR or DPC_WATCHDOG_VIOLATION
Whats the problem there ?
Any ideas ?
Thanks and best regards
Frank Uray
This might be a good place to start for these errors. There are some tech references to what exactly the error codes mean along with next steps.
Bug Check 0x133 DPC_WATCHDOG_VIOLATION | Microsoft Docs
How to fix Whea Uncorrectable Error! - Microsoft Community
And maybe a potential solution
[Solved] DPC WATCHDOG VIOLATION Blue Screen Window
I hope this helps!
Thank you for your answer !
I guess I will have to check it with nvidia.
One more thought, you say you have two GPUs. That is known to cause issues with Photoshop.
See section 7 in the attached link:
Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues
Dave
Thank you, this was helping !
I am able to open Photoshop now, but had some BlueScreens while closing.
I have the same issue with Photoshop CC 2018 with a very similar PC setup:
- Windows 10 64bit
- Intel i9-7980XE
- 32 GB Memory
- 1 Monitor
The crashes are very random but usually occur within a few minutes of starting to use photoshop. everything else on the system works fine, its just photoshop... it's forcing me to use the old photoshop cs6 i have (which is rock solid and never crashes). basically the new photoshop CC is un-usable in its current state on my PC.
It doesn't seem to be a "multiple GFX card" issue as i only have the one card and one monitor...!
any insights would be appreciated..!
cheers
ian
