I received the following error when publishing from AIR for iOS (AIR 27): unexpected failure: Signing Certificate is old.Does not contain team-identifier attribute
I created the Signing Certificate yesterday, so it doesn't make sense to me that it says it is old.
Thanks in advance,
Peter
you can check this, Troubleshooting common Adobe AIR installation errors with iOS applications
for that error, but in my experience, when you see that error you need to recreate (from step 1) your signing certificate and your provisioning profile.
what happens if you use air 26?
If I use Air 26, I get the following error:
Thank you kglad. I rebuilt the certificate and profile in Apple Developer, and now it works. Thank you!
you're welcome.
